Unread 12-26-2016, 08:52 PM   #1
Rigor
Finishing pan trough drain added after pre and pan with regular flange
THe shower is ready for standard 3 piece drain. after other tile guy left. She says she wants a trough drain. How do i connect that with normal drain flange, and does it require more parts. seemed it wasnt right. floating it in and just put exit over flange?
Brandon
Rigor is offline   Reply With Quote
Unread 12-26-2016, 08:53 PM   #2
Brandon,
Welcome to the forum.
WHat is the waterproofing on the rest of the shower?
Unread 12-26-2016, 08:58 PM   #3
Rigor
well no just pre slope and pan. She has a trough or trench drain with the exit on one side. Can i set it in dry pack with exit over the drain flange or do i need some kind of connector.
Brandon
Unread 12-26-2016, 09:25 PM   #4
Tiger Mountain Tile Inc
Take a look at the Aco drains. Also the Quickdrains (same link) may work or even work better.
You need a drain that is for a conventional shower- it will fit directly into your shower drain. Don't get one that relies on a surface membrane or has a membrane attached. QD and Aco make both types.
Jim Upton
DIYTileGuy
Idea for DIY Trough/Linear Shower Drain ryanschnipke Tile Forum/Advice Board 3 02-21-2011 01:23 PM
Pool Drain Trough thuffner3 Professionals' Hangout 9 09-25-2010 05:43 PM
Kerdi Drain - bottom part of regular drain golfnut_eh Tile Forum/Advice Board 7 11-30-2008 10:36 AM
Kerdi + trough drain John R Tile Forum/Advice Board 2 06-23-2008 07:52 PM
Kerdi with a regular shower drain in2explore Tile Forum/Advice Board 9 11-01-2006 12:57 AM
