Unread 12-26-2016, 01:30 PM   #1
SELLERSRODSHOP
couple of quick questions
I'm in the process of ripping out a bathroom that was built in 1959, so in major need of an update! I'm to the point of taping seams around the tub surround & putting the durock on the floor. I was curious if there is a certain thinset mortar you guys recommend for each proceedure or a good "catch all"that will cover the whole tile job.
Also, on the toilet flange, should it be fastened to the CBU then tiled around or fastened on top of the tile? I see it done all different ways on video's etc, but curiousa as to which way is recommended.
Steve
SELLERSRODSHOP is offline   Reply With Quote
Unread 12-26-2016, 04:01 PM   #2
The thinset you select is dependent on a couple of things:
- where you live and what's readily available
- the method and materials you are trying to bond
So, it's hard to advise you without a bit more information.
Unread 12-26-2016, 09:50 PM   #3
SELLERSRODSHOP
OK, thanks! I'm in Nashville TN, so fairly mild temps here. I'll be setting 12" porcelain tile over Durock CBU, so nothing really exotic.
Steve
Unread 12-26-2016, 10:23 PM   #4
Welcome to the forum, Steve!
Generically speaking, any decent modified mortar meeting ANSI standards A118.4 or better can be used under your Durock, for taping your seams, and setting your porcelain tile. If you've got large format tile on the floor, or would like the assistance of a non-sag mortar for the walls, that would introduce other mortar. I like the idea of having only one mortar. But if the job is big enough, I'll save a buck on areas that don't benefit from better mortar (like under the Durock) and use the savings for a higher performance non-sag mortar for the walls.
For the toilet flange...in a perfect world: the toilet flange would be installed atop the tile. But that's infrequent. Most times, removing and re-installing the toilet flange to the top of the tile isn't in the cards. In most cases, the cement board and tile are installed to 1/4" from the perimeter of the flange (just make sure to leave enough room for the closet flange bolts to slip under the flange). And extension rings are installed on top of the toilet flange so that excessive amounts of wax rings aren't employed in the installation of the toilet.
Unread 12-27-2016, 10:10 AM   #5
SELLERSRODSHOP
Thanks! Toilet flange isn't a problem. I've moved the toilet so just have the pipe stubbed out through the subfloor for the moment. I'll post some pics when time permits.
Steve
Unread 12-27-2016, 01:26 PM   #6
Ok, sounds good.
Then make sure to cut some slots in the tile for the screws that fasten the toilet flange down to the plywood floor to pass through. Either that, or be prepared to spend a bunch of time using a diamond hole saw to make holes in the tile for same after it's installed.
Couple of quick questions... knightsofni Tile Forum/Advice Board 2 05-10-2013 07:55 PM
Couple of quick questions djmceltic Tile Forum/Advice Board 3 04-08-2013 07:36 PM
Quick couple questions please 83trekker Tile Forum/Advice Board 62 12-08-2009 08:35 PM
Couple Quick Bathroom Questions depawl Tile Forum/Advice Board 3 12-13-2003 09:48 PM
Couple of dam(b) questions! Jman1120 Tile Forum/Advice Board 5 11-27-2003 04:12 PM
