Unread 12-12-2016, 10:15 AM   #1
ruscan
bathroom remodel question
Hello,
We recently bought an older home and I was thinking of remodeling the bathroom. I want to tile the shower around the existing bath.
I was wondering if that is something that is acceptable to do? If you look at the pictures (please excuse the mess, this bathroom is currently in bad shape and nobody wants to use it) you will see that bathtub has like three layers that are connected, I was wondering if its ok to remove the top two layers of this plastic material, install hardibacker and waterproof it and tile and just leave the bottom piece of the bath as is.
Is that ok to do so or would you recommend I should remove everything and install a new bath, just not sure how its done. I do have some previous tiling experience, but Im not an expert by any means.
Thank you all,
Greg
Greg
ruscan is offline   Reply With Quote
Unread 12-12-2016, 11:52 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Because of the design of that type of enclosure, integrating a tiled surround isn't really feasible.
Removing and replacing tub and building a proper tiled surround is a significant project. Will eat both time and $$. DIY will help, but not a "quickie" kind of thing.
Peter
Unread 12-12-2016, 07:38 PM   #3
ruscan
thanks fo rreply, I was afraid of that lol
but i do have time and a small budget. im not in a rush so i will give it a try. maybe it will take me a little longer but i want to do it right.
Should I start by removing everything then? taking it to the dump
So is there a specific bath that i should look for that is suitable for tile?
Greg
Unread 12-12-2016, 08:14 PM   #4
Edmonton,
Just how small of a budget are you talking about? Proper waterproofing costs around $20 per sf, add tile, grout, thinset, backerboard, caulking.....
Unread 12-12-2016, 09:22 PM   #5
ruscan
i have 2k available right now, i could probably allocate more $$ at a later date.
i think this should be a good start anyway, maybe buy some items on boxing day
Greg
Unread 12-12-2016, 09:56 PM   #6
If that's US dollars you should be OK
Unread 12-12-2016, 11:34 PM   #7
ZZZK
$20 a sqft for waterproofing Paul? The DIY material cost for both liquid and sheet membrane from all the big boys is closer to $2 at most. Backerboard is another $1 at most. Preproofed foam board like Kerdi board is like $4ish. Still don't see how you got to $20.
John
ZZZK is offline   Reply With Quote
Unread 12-13-2016, 11:04 AM   #8
Todd Groettum
Theoriginaltileguytodd
He added Labor John
American standard Porcelain tub around 265-280 Kohler 350 - 600 Minimum up to 1500.00 for top quality
Since you will be tiling, Spend some money and get a decent Porcelain tub...Mid quality Kohler.
tub - 600
CBU, thinset, Redgaurd - 240
Tile & Trim - 500
Incidentals - 100
Additions.
Plumbing , Sheetrock, Paint, Fan/ Light unit
Yea, you can do it for 2 grand if you are careful and spend Wisely for top quality where you should have it....
Add a couple hundred bucks for getting that new tub in place...You will need help and Beer is expensive
This American standards a Pretty good tub for the money also
https://www.build.com/american-stand...athtub/s132294
Todd
theoriginaltileguytodd
Todd Groettum is offline   Reply With Quote
Unread 12-13-2016, 11:54 AM   #9
ruscan
Should i use regular Sheetrock and some schluther cover as someone suggested on other thread or would you recommend using cbu. I previously worked with hardibacker and it was a little tedious but I dont mind it and will do it again if its a better option over kerdi.
thanks for the price break down - it does help!
I should also mention that I'm in Canada, and my 2k budget is in CAN dollars.
Greg
Unread 12-14-2016, 07:09 AM   #10
Todd Groettum
Well if its canadian dollars no way....ROFL...
Choosing method is your call...Spend a little time in here researching...I have built alot of CBU ( Durock, Wonderboard etc)Tub Showers as have a thousand + other guys with much success....
Going the CBU route will cost a little less but the stuff is heavy ( it gets heavier when the job requires several pallets worth )
One thing...if your outside walls are sheetrock and you use CBU, make sure you have a factory edge up to your cut sheetrock and leave enough room to tape this and tile just beyond the edge of the cbu outside the tub area..( generally around 2" give or take)
Todd
Unread 12-14-2016, 10:02 AM   #11
ruscan
damn it! i was hoping the loonie would be worth something
thanks, I probably go with the CBU, i have no experience with schluther products.
Greg
Unread 12-14-2016, 11:29 PM   #12
argile tile
i agree it could *end*up* beginning as a long DiY project and become a significant project. think 2x about starting and read this forum's past projects for "what might go very wrong". and for time saver methods (like uses of a curb)
a bathtub was quoted for $350-$1,500 despite the $2000 budget. obviously unless you need drought water storage, you could do just the shower
Argile
argile tile is offline   Reply With Quote
Unread 12-14-2016, 11:35 PM   #13
my bad, I meant $2 per sf for waterproofing.. my bad typing
Unread 12-17-2016, 12:07 PM   #14
Tiger Mountain Tile Inc
It'd be a shame to tile the surround and not replace the faucet while you have access to it. Moen's are like Toyota's. A Positemp valve and Eva trim will run about $175.
Along with what Todd said- this is the tub that I've been putting in for my customers. It's deeper than a normal old tub. There's a special drain kit to go with it too.
Jim Upton
DIYTileGuy
Unread 12-18-2016, 08:13 AM   #15
Todd Groettum
Nice tub...Lots of bang for the Buck...
Todd
bathroom remodel question rodgerram Tile Forum/Advice Board 3 10-20-2012 06:49 PM
JackW Bathroom Remodel-Subfloor Question JackW_DIY Tile Forum/Advice Board 5 01-18-2011 09:16 AM
Bathroom remodel question justbeachy42 Tile Forum/Advice Board 3 05-19-2009 10:30 PM
bathroom remodel question jfarmakis Tile Forum/Advice Board 1 03-01-2008 09:05 AM
Plumbing Question for bathroom remodel AdamDH Tile Forum/Advice Board 40 11-12-2005 04:32 PM
