Unread 12-08-2016, 09:31 PM   #1
dzustee
Should I re-grout my shower with epoxy?
I have attached pictures of my shower floor. This is the original tile and grout. I clean this every eight months to a year or so. But now it's getting nasty looking again. My question is if I regrout my shower at least the floor, with epoxy grout, will I get less of this nasty build-up?
Except for the shower floor, that grout and tile are in amazing shape for being 38 years old.
Maybe this discussion belong in some existing threads? I don't know. Any help would be appreciated.
Justin
dzustee is offline   Reply With Quote
Unread 12-08-2016, 09:46 PM   #2
Grasshopper
Try grouting it instead. Use the same as what's in there. It's holding back water that gets in the grout above. Grout will let it dry out quicker.
Also, clean it more than every 8 months (unless I misunderstood what you wrote). At least spray it with some tilex (or similar) more often and give it a quick scrub with a corner brush. Don't forget your soap scum is building up down there, which is food for some organic growth.
Mark
Grasshopper is offline   Reply With Quote
Unread 12-08-2016, 10:33 PM   #3
dzustee
Yeah you read it right...sounds like it's a me problem! Guess I need to clean more often! Thanks
Justin
epoxy grout in steam shower? JAYLUPARK Tile Forum/Advice Board 2 11-03-2010 11:52 AM
TEC AccuColor EFX Epoxy Special Effects 3 part epoxy grout Soup2Nuts Tile Forum/Advice Board 22 10-16-2010 09:51 PM
Epoxy Grout Shower Floor RubenDog Tile Forum/Advice Board 13 05-04-2009 12:18 PM
epoxy vs. unsanded grout in shower jhonig2 Tile Forum/Advice Board 0 09-06-2006 07:42 PM
Modified Epoxy Grout vs. 100% Solids Epoxy Grout dmorian Tile Forum/Advice Board 8 03-08-2006 09:12 AM
