Unread 04-03-2016, 02:10 PM   #1
rmf
How do you line up wall grout line with ceiling tile?
I installed my ceiling tile first and I could use some advice on ways I can make sure my wall grout lines meet up with the ceiling. I used a stack bond pattern.
I really did not give this problem much thought before starting because I just figured I would run a chalk line, but with a lack of tile setting experience, I am now realizing this will not be as easy as I originally thought.
Any advice appreciated!
Rob
rmf is offline   Reply With Quote
Unread 04-03-2016, 02:24 PM   #2
Use a highly accurate level to transfer perfectly plumb lines from the ceiling down the wall. Then use a highly accurate level to make perfectly level lines on the walls so that your tiles are both level and plumb as you install.
It's been my experience that a majority of levels are not accurate. They get much better as you spend more money for these tools. But you can easily test any given level by reading where the bubble falls within the vial markers, then rotating the level end for end (with same surface of the level against the exact same spot on the wall) and compare where the bubble falls within the vial markers. If the bubble reads the exact same in both positions, it's accurate on that particular vial. Don't forget to check all the vials on the level before assuming that they are all accurate. I check every level I intend on purchasing, from cheap to expensive, before purchasing.
Unread 04-03-2016, 03:30 PM   #3
What Bubba said.
I know it's too late now but many times we run the ceiling and floor on a 45 to purposely off set the joints.
Unread 04-03-2016, 06:26 PM   #4
A vertical rotary laser will help.
wall and shower pan not in line mcleester Tile Forum/Advice Board 3 07-19-2015 08:11 PM
Ceiling & Tub-line Caulk Color??? muskie36 Tile Forum/Advice Board 2 08-23-2014 12:42 AM
Grout line size for shower wall jdkimes Tile Forum/Advice Board 5 09-30-2006 01:33 AM
Granite tile grout line on cut edge Marge Tile Forum/Advice Board 23 12-13-2005 08:00 PM
Tile Gap/Grout Line - less varencheap Tile Forum/Advice Board 7 05-03-2005 10:02 PM
