Unread 01-20-2015, 02:59 PM   #1
HomeDepotAssociate
HomeDepotAssociate's Avatar
Grout Caulk a wet area no-no?
I was lurking some old threads here in light of a customer who had used polyblend grout caulk at the base of a tub and after 3 days it began to soften again. . I noticed on an old thread someone had the same issue, and said custom told him its not actually okay to use that near somewhere that is exposed to repeat moisture.
A little confused becuae wouldnt that include sinks (which is featured on the bottle as a great spot to use this stuff). Is silicone just a better option in most/all cases? A little help for my soul
Kontorsion
(Chate')
HomeDepotAssociate is offline   Reply With Quote
Unread 01-20-2015, 04:28 PM   #2
Lump
Lump's Avatar
100% silicone is almost always the better way to go. Keep away from the caulks in most cases.
Brad L. Lenz
NTCA Proud Member
Unread 01-20-2015, 05:27 PM   #3
Acrylic and "siliconized acrylics" are not rated for continuously wet environments. They tend to break down with such exposure. Technically, it could be used for a portion of some vertical corners, but the bottom horizontal corners at the base of the shower or tub are typically exposed to continuously wet conditions. Yes, the surface of the tile dries between uses, but the tile assembly typically gets moisture inside and continuously exposes the backside of the caulk to moisture.
I will nearly always use a 100% silicone sealant in wet areas. And it's much more flexible than the acrylic caulks, so it's less prone to ugly cracking.
Unread 01-22-2015, 06:15 PM   #4
HomeDepotAssociate
thanks dudes. I will keep that in mind when advising folks out here. I had no idea!
Kontorsion
(Chate')
Water behind caulk, wet grout lines redcrawl Tile Forum/Advice Board 4 06-03-2011 02:35 PM
Tile non-wet area walls FJK Tile Forum/Advice Board 10 01-27-2010 05:43 AM
wet area grout, which one? olzo55 Professionals' Hangout 5 02-23-2008 12:28 PM
adding dry grout mix to wet caulk for faux calk? GHutchins Tile Forum/Advice Board 5 04-12-2006 11:03 PM
Can I use thinset over drywall in non-wet area MaikeruM Tile Forum/Advice Board 1 01-29-2006 04:08 PM
