Unread 03-10-2014, 01:45 PM   #1
HomeDepotAssociate
HomeDepotAssociate's Avatar
Urethane Grout & Grout Release
Been digging through these forums but the threads that address this don't quite get to what im wondering. . Greetings everyone by the way
Had a customer asking for a "sealer" for urethane grout, but upon further questions I was made aware that he was needing grout release per the urethane grout instructions. From talking with you guys I knew what he was talkin about but I wasn't quite sure if we carried grout release and I was right, we don't, in store at least. I told him he would either have to go online to HD.com or try *ahem* Lowes if its urgent. However I think the guy. . . must'v thought I didn't know what I was talking about because when I told him it wasn't something we carried he already had 511 in his hand and as I type this I see him walking to the registers with it. But I told him (perhaps erroneously) that it wont work, or at least he's spending way too much to potentially seal porcelain tile.
My Q for you guys is, when ur installing with urethane grout. . the grout release is to keep the urethane from permanently discolouring the tile? Do you need it every time? Im familiar with grout release's function but not entirely sure apparently why you would not want to use a regular sealer when installing tile other than the fact that. . I know you guys would probably tell me you shouldn't.
Kontorsion
(Chate')
HomeDepotAssociate is offline   Reply With Quote
Unread 03-10-2014, 04:26 PM   #2
Lazarus
Lazarus's Avatar
"Grout release" is typically used on quarry tiles....in other words, tiles that are "clay fired" and have a high level of porosity....restaurant use, etc. A standard ceramic or porcelain tile really don't require it.
Laz...
“Always listen to experts. They'll tell you what can't be done, and why. Then do it.”
Unread 03-10-2014, 05:09 PM   #3
HomeDepotAssociate
so then I was right in my suspicion . . I think. . is that correct that it will be almost impossible to tear away if a grout release isn't used before applying a urethane grote? when it is needed?
Kontorsion
(Chate')
Unread 03-10-2014, 05:51 PM   #4
evan1968
Not So Senior Contributor
evan1968's Avatar
Your avitar freaks me out.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 03-10-2014, 06:09 PM   #5
reefone
tile setter
the only time I use a grout release is for quarry tiles like mentioned above. quarry tiles are very porous and sometimes the grouts color will stain the quarry tile if a grout release isn't used. don't ask how I know this. for porcelain or ceramic tile it really isn't needed as the glaze on top is like a sealer.
Jerry
tile setter 12yrs exp.
Urethane grout & expansion joints T_Hulse Professionals' Hangout 14 07-14-2012 01:35 PM
Difference between Urethane Grout & Epoxy Grout? HomeDepotAssociate Tile Forum/Advice Board 15 07-09-2012 09:31 PM
Using grout release to clean up grout residue on slate tiles Angela78 Cleaning, Restoration and Sealing 1 10-11-2007 10:37 PM
Grout release on glazed ceramic tile before black grout application? tommyt Tile Forum/Advice Board 7 04-17-2005 11:12 PM
Sealer, grout release & MB-4 questions yadax3 Cleaning, Restoration and Sealing 7 09-05-2004 10:27 AM
