Jason,
My thought is this. That area is going to get the MOST traffic through the shower. A grout caulk, not caulk alone, will give it the flexibility to move a bit and not crack out. Also, that is going to be a high water area, with alot of splashing on it. This siliconized grout will keep that water moving towards a floor designed for just that purpose and help reduce the amount of water that has to go to through the tile to the pan. This was just my opinion and conforms to every code I know of. And, if you read the first sentence, you would see that I said grout was fine. So, where is the bad advice? I routinely grout caulk areas that I know will have a lot of traffic just to ensure that they don't crack out. Rarely is it needed, it just makes me feel better. Also, grout caulking around the shower floor in the corner is another thing that I do just because I feel better having it where two different planes meet.
Matt
