Unread 10-03-2012, 05:41 PM   #1
oakview
Retired Moderator - Owned by two rescued greyhounds
oakview's Avatar
Electrical Question
In the course of doing your business with tile, many of you guys must have had to reconnect wiring to outlets and such. Looking for ideas how to reconnect wires in a tricky (for me) situation.
Got a 3-gang box with a GFCI, and single rocker light switch, and a 3 rocker fan combo switch. 8 - 3 strand Romex cables terminate in this box for a total of 24 wires. Easy enough to take it all apart, but definitely harder to put it all back together after putting up new drywall.
Got any tips like numbering, grouping with tape, anything?
::DaveG::
The Tile and Stone Magazine for Consumers!
New to the Forum? Read this! :.: Click here to add your name to your signature.
"If you don't have time to do it right, when will you have time to do it over?." -John Wooden
oakview is offline   Reply With Quote
Unread 10-03-2012, 05:48 PM   #2
Take a picture or three before taking it apart.
Use colored electrical tape to mark the wires
Write things down.
Take as little apart as you need to, pulling the switches and GFI forward to get the drywall replaced.
When swapping out the switches, do one at a time.
And it sounds like the box is overloaded.
Unread 10-03-2012, 06:34 PM   #3
tilejoe
tilejoe's Avatar
You could always get a larger box with a smaller trim ring. Or make it into 2 separate boxes. 2 2gang boxes...
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 10-03-2012, 07:06 PM   #4
oakview
oakview's Avatar
It usta be two separate boxes. One was an original 2 gang, the other a singe that was retro-fitted and had them little ears to hold it against the drywall. I pewt everything into the 3 gang, now I gotta take it apart again and drywall the bathroom.
It's just under the limit. I bought a larger box, 50 c.i. - I have 22 conductor units calculated using the NEC tables, so 44 c.i. would be enough. Thanks for mentioning that though, it was totally by accident I got the bigger box. It wasn't until later that I found out about how to correctly size the box.
::DaveG::
Unread 10-03-2012, 09:17 PM   #5
Steve C
Steve C's Avatar
In my experience, a wire marker book is a lot handier than trying to use tape.
Steve
Steve C is offline   Reply With Quote
Unread 10-04-2012, 06:34 AM   #6
Mountain Tile
Pashley Tile
Best way is to let the electrician do it.
Chuck
wwwpashleytile.com
Mountain Tile is offline   Reply With Quote
Unread 10-04-2012, 07:47 AM   #7
Steve C
Steve C's Avatar
Easier said than done around these parts. It's not "let" the electrician do it, it's "get" the electrician to do it. Hard to find one who'll show up for such a demeaning, un-important little job.
Steve
Unread 10-04-2012, 10:22 AM   #8
oakview
oakview's Avatar
In this case, I am the "electrician". I didn't have ready access to wire markers so I made up my own using white electrical tape - worked pretty darn good too. Markers + photos as suggested by Paul made the job a whole lot easier. After reconnecting everything, the tester shows all is good. Thanks everyone.
::DaveG::
Unread 10-04-2012, 10:31 AM   #9
I don't understand why you can't just let everything hang out of the box without disconnecting anything. Tape it all up so you don't juice yourself.
Unread 10-04-2012, 02:25 PM   #10
advertguy2
^ One reason may be that putting up the drywall then cutting around the box with a rotozip is typically easier and neater than cutting before hanging. Can't use the rotozip if the switches and stuff are protruding from the box. Of course, thats just a guess because I'm terrible at measuring/cutting box locations and use the rotozip method all the time.
advertguy2 is offline   Reply With Quote
Unread 10-04-2012, 07:30 PM   #11
oakview
oakview's Avatar
Exactly - is always the way I do it. My dad bought me the tool years ago and have used it for that sorta task among other things. Handy little tool to have.
::DaveG::
Can anybody answer an electrical question lasvegaslenny The Mud Box 10 05-05-2010 11:37 PM
Electrical Question Marge Tile Forum/Advice Board 9 12-01-2007 07:59 PM
Electrical question Dave Taylor Tile Forum/Advice Board 13 03-18-2007 01:23 PM
Electrical question Robertp777 Tile Forum/Advice Board 9 08-05-2006 10:43 AM
Electrical question Sonnie Layne Professionals' Hangout 38 07-16-2003 03:55 AM
