Unread 08-14-2018, 08:15 AM   #1
J-Cred
Anyone Want to Install For me in NJ?
Hi all,
I recently had a guy come out who was wanting to lay down wire on the 2nd floor. I have never heard of such a process before. I knew I wanted to use strictly backerboard. After doing research on this, I came across this method found on here. As you are aware it is the Jersey Mud Job.
I know a lot on here do not recommend this due to it not being a TCNA standard (unless it is thickset).
Anyone interested in installing approximately 800 sq ft of large format plank tile in a brand new built home on the 1st floor and 2nd floor?
I go to settlement on August 23rd and I am looking for this to be started on August 24th or around that time.
I am located in South Jersey; Sicklerville, NJ.
I have the tile already and grout. I can pick up the rest of the supplies (mortar & backerboard) if needed.
I am not sure if Ditra will save enough in labor to offset the cost of installing CBU.
Let me know. Thanks
Jeff
J-Cred is offline   Reply With Quote
Unread 08-14-2018, 05:56 PM   #2
Jeff
Good luck finding an installer on short notice. I would try to local tile shops you may get lucky. Right now in this area most decent mechanics are booked out 3-4 months.
Best of luck
Bathtub Drain Install - How to install with no access below? rodneyc8063 Tile Forum/Advice Board 6 03-04-2016 11:23 PM
How not to install BB Hammy Professionals' Hangout 4 01-13-2011 04:46 PM
Cove base install thin lip vs. flush install faithinGod Professionals' Hangout 27 10-12-2010 06:08 AM
kerdi install basement install tileme Tile Forum/Advice Board 65 11-01-2009 09:34 AM
Swanstone Retrofit Shower Base Install Advice and some hints on Warmly Yours Install cjmartin315 Tile Forum/Advice Board 11 04-05-2007 05:52 AM
