Unread 09-13-2020, 02:04 PM   #1
qwertyjjj
Mortar for under water heater
I'm finding self leveling concrete a bit expensive and I have 2 bags of mortar mix lieing around.
I need to add a 3/4" layer of cement/mortar for a water heater in a closet - just 4' x 2.5'
How many sq ft does a 60lb bag of mortar cover?
I can only find calculators for brick laying
Gordon
qwertyjjj is offline   Reply With Quote
Unread 09-13-2020, 03:26 PM   #2
jerrymlr1
19 sq ft @ 3/8"comes to mind. Half that at 3/4". The specs are sometimes on the back of the bag.
Jerry
Unread 09-13-2020, 04:15 PM   #3
Curious why you'd want a 3/4" layer of mortar mix under a water heater. This to be a wear layer?
The 60-pound bags of various cement-based mixes can usually be counted upon to be about half a cubic foot in volume. Maybe a little less, depending upon just what it is you have.
How long them bags been "laying around?"
Unread 09-13-2020, 07:21 PM   #4
I would bet that the weight of a water heater spread out over 3-4 tiny feet will break that mortar into little pieces if it's over a wood subfloor.
Unread 09-13-2020, 07:29 PM   #5
I bet it will do that if it's over a concrete subfloor, Kevin.
Unread 09-15-2020, 08:15 PM   #6
I'm thinking Jerry is about right on his figures. Two bags should do it
James Upton
Hot water heater on Travertine cmdmoto Tile Forum/Advice Board 12 02-20-2011 09:42 AM
Water heater / Water pressure REXAMUS The Mud Box 2 01-02-2011 01:29 PM
Tile saw water heater AZ10sBum Tile Forum/Advice Board 2 04-12-2009 08:53 PM
Gas Water Heater ddmoit The Mud Box 29 01-15-2008 04:18 PM
bucket water heater? Jon1029 Tile Forum/Advice Board 5 01-10-2005 06:03 PM
