Unread 04-08-2010, 11:32 PM   #1
toyage
Radiant Floor heating cables--what is the best brand(s)
Electric radiant heating cables--does anyone have an opinion about which brand or brands are the best? Any brands that have a distinct advantage in terms of quality or ease installation? Any brands to avoid? I would really like to hear from guys who have done a number of installs.
Tim
toyage is offline   Reply With Quote
Unread 04-08-2010, 11:44 PM   #2
MarkTarkus
MarkTarkus's Avatar
I have used Suntouch on a dozen or so jobs, Easy Heat and Raychem a couple of times. I thought Suntouch was the easiest to work with and seemed like the most durable. The mats are nice but pricey. Suntouch, and most companies, make a mat (cables intertwined in a roll of mesh) and a cable type (a roll of cable that you string between brackets that you attach to the floor.) The mats are usually easier to use if you have a pretty square open area. The roll cable is nice because you can weave it around obstacles a little easier (toilets, doorways, pipes walls etc.) The cables aren't too bad but you just have to keep your spacing really precise so as to not run out of cable too soon or have a bunch left over.
It's super important to not get too big of a kit for your area. You can't cut the cable. My advice would be to send a diagram of your area to whichever company you choose and they will help you select the best kit.
That's my 2 bits. I know Laticrete now has a cable but I have not used it.
concrete in a bathroom (heating cables) miroslav_karpis Tile Forum/Advice Board 2 01-29-2009 11:46 PM
Thinset layer over heating cables - how smooth does it need to be? Fairview Tile Forum/Advice Board 7 04-22-2008 08:11 PM
Radiant Floor Heating Help silverbottom Tile Forum/Advice Board 3 01-12-2008 10:08 PM
self leveling cement over floor heating cables handymansteve Tile Forum/Advice Board 5 02-13-2007 01:58 PM
Heating cables covered by new vanity Bri Professionals' Hangout 6 04-20-2004 03:30 PM
