Unread 05-08-2009, 06:12 PM   #1
lacrebob
Redgard mortar shower pan that already has rubber liner?
I've built a shower pan with a mortar base (sloped), rubber liner, and mortar base on top of the rubber liner.
I'll be using redguard as my waterproof membrane for the Hardibacker walls and shampoo alcoves.
This shower will have ceramic tile on the walls and porcelain tile on the floor.
Is there any harm in using Redguard for this shower pan since the pan already has the waterproof membrane? Would water get trapped? Does application of Redguard lessen the bond between porcelain tile and the mortar pan?
lacrebob is offline   Reply With Quote
Unread 05-08-2009, 06:22 PM   #2
TileArt1
TileArt1's Avatar
Hey lacrebob,
No need to use redgard on the floor. It may not create a true "moisture sandwich, but it certainly won't help anything. It may not allow the weep holes to work as effectively, I don't know. I would just use the redgard on the walls down to the floor.
Roger (The FloorElf)
Unread 05-08-2009, 08:51 PM   #3
lacrebob
That works for me.
OK to use Redgard before rubber shower pan liner sdnomad Tile Forum/Advice Board 2 12-14-2007 02:31 PM
Shower pan liner - CPE vs Redgard jacko93 Tile Forum/Advice Board 3 09-03-2007 07:52 AM
How to remove rubber gasket from pre-formed shower pan sohcrates Tile Forum/Advice Board 3 01-12-2007 07:02 PM
Mortar Mix for Shower Pan Liner den110 Tile Forum/Advice Board 19 03-16-2006 10:04 AM
Copper Shower Pan Vs. Rubber Membrane emptysea Tile Forum/Advice Board 16 12-07-2005 06:22 PM
