Unread 07-19-2008, 08:47 AM   #1
WarrenC
how to attach Schluter edging
I purchased some Schluter edging for a countertop, and it comes with a flange with some large triangular holes in it. How do I hold this in place until I start the tile work. Staples, roofing nails etc? Of course I need something that wont stick up too high.
thanks
WarrenC is offline   Reply With Quote
Unread 07-19-2008, 08:50 AM   #2
Crestone Tile
Gonzo!
Hi ... just embed it in thinset during your tile install. No fasteners.
Matt
"Shut it down!"
Crestone Tile is offline   Reply With Quote
Unread 07-19-2008, 08:52 AM   #3
ddmoit
ddmoit's Avatar
Welcome to the forum, Warren.
What Matt said.
Here's a Youtube video of a similar product being installed...
http://www.youtube.com/watch?v=ucmMfOKs_4A
Dan - a DIYer in SE Tennessee
Unread 07-19-2008, 11:49 AM   #4
WarrenC
thanks guys, the youtube video really helped
WarrenC
Unread 09-17-2009, 04:58 PM   #5
Guitarman1
Unfortunately, the creator of that You Tube topic removed it from the web, so it is no longer available. I was very excited hoping to see it!
Rob R.
Rob
Guitarman1 is offline   Reply With Quote
Unread 09-17-2009, 05:29 PM   #6
ddmoit
ddmoit's Avatar
Maybe this one will help....
http://www.youtube.com/watch?v=E1v4hZ2cPDg
Unread 09-17-2009, 05:32 PM   #7
the thinset attaches it with the holes and the tile helps hold it in place.
^^Check out our Blog^^
Unread 09-17-2009, 05:36 PM   #8
RedRock
Granite, Quartz, and Tile Installer
RedRock's Avatar
Its better to install them as you set tile but if you can't, then use either roofing nails or pneumatic staples. Be careful not to bend or break the profiles when securing them.
Juan
__________________________
You are never too old to set another goal or to dream a new dream. - C. S. Lewis
RedRock is offline   Reply With Quote
Unread 09-17-2009, 10:39 PM   #9
The Kid
The Kid's Avatar
I had a real tricky install once and set the trims vertical on the walls with hot melt glue to tack in place , the struck thinset into the voids with my margin trowel and set the tile.
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
