Unread 04-28-2007, 11:04 PM   #1
trihai
A shower curb with cement board and Kerdi
Hi,
If I use Kerdi membrane, can I use 1/2" cement board to build a curb? The cement board will be installed on top of the wood and Kerdi membrane on top of the cement board.
I really don't understand why people have to have a mortar curb built when they use Kerdi membrane over it? Could someone please explain?
Thank you.
Trihai
trihai is offline   Reply With Quote
Unread 04-29-2007, 06:56 AM   #2
muskymike
muskymike's Avatar
Hi Trihia, I think you are thinking of a shower with a pan liner that has a mortar curb. If you are using Kerdi you don't need it because the curb can be wrapped with drywall or cbu and covered with Kerdi.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 04-29-2007, 08:06 AM   #3
Hi Trihai,
What Mike said.
Unread 04-29-2007, 09:09 PM   #4
trihai
Hi,
Thanks for your replies. However, I have seen many photos in which people use Kerdi with a mud curbs. Is that a habit or just because a mud curb is stronger?
One question: can I use Kerdi over the wood, no CBU?
Thank you.
Trihai
Unread 04-30-2007, 01:41 PM   #5
JTG
JTG's Avatar
Don't put the Kerdi directly to the wood on the curb. Yes you can wrap with CBU and make sure that you also put a little bit of slant inward on your curb. I like to lay in a thin piece of metal trim used to transition carpet to vinyl. It puts just a little lift on the outside edge and water will run into the pan.
Good Luck
JTG
Jerry
Santa Seattle
Ballard
