Unread 05-01-2005, 07:00 PM   #1
larry528
Tile used as wall trim in bathroom
I am planning on a tile job in a bathroom. It would be my second tile job, I have confidence now, but I still have questions.
The question is, I would like to use tile as the wall border replacing the wood trim currently used. Can I tile directly on the sheetrock, or do I need something else as a backer?
If I have to use something else, i will just slap back wood trim, but if I can use tile, I like the idea of using that.
PS, I now look at tile jobs all over with a keen eye for ideas. Offices, restaurants, even bathrooms where I work. They look different now that I know what is behind them getting there. Some jobs are very good, straight lines, neat grout, some, well, they must have taken the low bid
I cant help all the questions, after all, I am an engineer!
larry528 is offline   Reply With Quote
Unread 05-01-2005, 07:32 PM   #2
Hi Larry, are you talking about around the bottom replacing the wood base? You can tile right to the sheetrock with thinset or mastic. Is this clean sheetrock or is it painted?
Unread 05-02-2005, 10:09 AM   #3
larry528
The area is part plain, untextured sheetrock, but it also has some wallpaper. My plan is to put a 3 inch high tile on the sheetrock standing above the floor tile. So i will need to carefully remove some wallpaper. Do i need to do any other prep besides removing the wallpaper?
Remove any excess wallpaper paste residue?
Also, do I plan for grout between the wall tile and the floor tile, or place the cut edge of the wall tile directly on the floor tile?
Unread 05-02-2005, 10:42 AM   #4
jdm
jdm's Avatar
Larry --
Yes, scrub the wallpaper paste off the wall and let the sheetrock dry.
Leave about 1/8" space between the trim tiles and the floor. Fill the space with caulk, not grout, since movement is likely at that joint. Caulk that is color-matched to the grout is available.
BTW, I have a cousin Larry whose birthday is 5/28, but he's not from Texas.
jeff
Go Rutgers!
