I'm beveling my outside corners as well. The problem I'm having is that the 10" blade flexes out as i cut the bevel.
I have a Lowe's Kobalt 10" sliding wet saw. It came with a Kobalt 10" continuous diamond blade. I'm using it on 16"x32" porcelain tiles. The tile is clamped, upside down (the finished side down), on the sliding saw table and positioned so i leave a factory edge of about 3/32".
How do i keep the bevel cut straight and true...
- use a longer diameter washer to secure the blade and lessen the flexing?
- use a 7" blade guessing that a smaller diameter would result in less flexing?
- use a better 10" continuous diamond blade?
thanks
