Originally Posted by John
The manufacturer's spec. sheet makes it sound amazing
At more than $50 a bag, John, I think it certainly should be.
I guess it is not a "thinset" and can be used in thicker depths?
Thinset or thin-set is a method, not a material. While that 254 mortar says it meets ANSI A118.15 as a "super mortar," I see no T in the designation indicating that it has non-sag properties, which is usually an indication that the manufacturer is going to indicate it for use in thicknesses greater than 1/4-inch. But even those mortars that are indicated for use in thicknesses up to 3/4-inch are still thinset mortars.
In any case, from their TDS, Laticrete intends it to be used as a thinset mortar and nothing else. If you want to build up those repair areas, you'll want to do it with something other than your thinset mortar.
