The material on top and bottom of Kerdiboard is there for a few reasons:
- it helps with vapor transmission. While the EPS may be liquid water tight, it may not be vapor proof. And, the density of that in Kerdiboard is fairly high.
- it helps with the bending strength because the material doesn't stretch or bend as easily as the foam, so it helps keep everything straight and flat
- it aids some in the thinset bond. But, there are enough micro pockets in foam for thinset to bond quite well. Another but, though, the crystals grown in the cement are fragile, and the raw foam is more flexibly, which could break them, weakening the link. the bonded on films should be more stable, and thus, promote longevity in the bond.
All of the tileable foam core panels have some sort of coating on them to overcome the above potential problems. There has to be a reason for this.
