I recently had a new custom shower installed in my master bathroom: gutted the room and did a new build using Schluter waterproofing system, Kerdiline nearly flush to the wall, foam curb and sloped pan. The base, curb, and surround walls are all tiled with 18 x 18 ceramic tiles. Shortly after the contractor cleared out and cleanup was finished, I discovered the base had a low spot that pooled water. Checked with a level and there was a localized negative slope away from the drain. I don't think a water test was done or it would have been apparent.
Youtube video link.
I'm looking for the
most effective ways to repair the slope problem. We requested the Schluter system for the install due to the reputation and warranty and I'd like the repair to be just as effective and warrantable. Several contacts have suggested options:
1 - Tile over the base
2 - Rebuild the base and tie in to the existing membranes
Of these options, what would be the pros/cons, especially any reduction in the long-term durability of the overall waterproofing? For example, I'm wondering how you could get around destroying the integrated Kerdiline membrane if trying to tile over the base. Wouldn't the existing drain need to be removed to fit it to the new height of the tiles, ensure good waste connection, and tie in the membranes to rest of the shower?
Other considerations: there is an alcove in the shower wall with a negative slope that has to be fixed, and the water supply and flow control protrusions did not have Schluter waterproofing collars (or any other material) put around them and may need to be opened up to waterproof them.
I'd appreciate your thoughts so I can push for this to be repaired effectively. Thanks guys.
