I am writing for your help in 1) convincing my husband that this repair to our front porch is not a DIY job that he should attempt and 2) learning enough so that I can hire a competent tile setter to correctly fix this job for me.
A few years ago we had our front porch tiled with an exterior grade porcelain tile. We used a local tile store, not a big box store, and we hired the tile setter recommended by the shop. A couple of years later after a cold winter some of the front step tiles sounded hollow when you stepped on them and seemed loose. We called the tile setter who came out and repaired them. Fast forward to this year, about one year later, and most of the front step tiles started popping off. As they became loose I could reach down and just pull them up. I have attached pictures showing the step with its missing tiles, a picture of where the tiles remain attached to the step and a shot looking down at the top of the step where the mortar is attached to the step but came fully loose from the tile.
You probably can't tell from the pictures but the step apparently was not level from side to side and the tile setter had just added more mortar as he went along to make it level until at one point there are two tiles, one on top of the other, used to make the step level. I'm certain that this is not standard practice (but those tiles do, amazingly, remain stuck tightly to the step). Also when I pulled up the tiles it did not seem that the mortar had been laid evenly and there seemed to be just blobs of it in some places and no mortar at all in other places.
Now I need to get this fixed. If it is a simple job my husband, who is actually very handy, will attempt it but he has little tile experience (he's repaired bathroom shower walls and put in a kitchen backsplash) and certainly no knowledge of exterior tile work which from reading these forums is a real science. Any information on what we need to do will be appreciated. Do we need to remove all the tiles from the steps and start over? Can we just replace the missing tiles? What kind of prep work and mortar should be used? What are the vocabulary words I need to learn so that I can talk to the tile setters and have any hope of assuring that they are suggesting the correct repair.
Thanks for your help!
Jane
