Unread 10-12-2005, 05:39 PM   #1
WackyStacker
Tiling Over Existing Shower Pan
Hello,
I have a few questions about a bathroom shower remodel project? My experience level is intermediate.
The house is 30 years old, I remodeled 2 of the bathrooms already.
I am getting ready to remodel the final bathroom which has a shower stall the same size as a bath tub.
I am going to build a 33" partial tile & glass block wall (not going to the ceiling) as we no longer want shower doors. The entry to the shower will be around 26 inches or so.
My question is can I tile over the old existing shower pan?
Pan Condition: the old shower pan is in good sound shape, not squishy just dirty & stained. I was thinking I might tile right over that old shower pan. Just in case it may become squishy I was going to spray some foam underneath the pan to cover any unforseen problems that may arise in the future. I planned to attach the partial wall on top of the pan edge and to the studs in the wall.
Now if the answer is YES to all ..............
Will the mortor and tile hold on to that old pan or does it need to be treated with something or will I use cement board?
Just screwing in a new drain, will it reach? Yes? No? It looks like it will?
Any advice would be greatly appreciated.
Robin
WackyStacker is offline   Reply With Quote
Unread 10-12-2005, 06:15 PM   #2
scott anthony
Tile Man -- Central Florida
scott anthony's Avatar
I have overlayed a couple but not at at my expense. I had to save a hack.
To set the tile I used Mapei white unsanded thin set or (pre mix)but mixed wet. It will look or feel like flour and water. You need to determine if your drian will raise the depth of the tile you are adding. Sometimes they are tough to unscrew after they have aged a bit. I usually had to break out the area around the drain so I could get a good grip on it, then I mud it back.
Is it the desired way, I think not. Is it the easiest, I think so.
Hope this is what your looking for .
scott anthony is offline   Reply With Quote
Unread 10-12-2005, 09:40 PM   #3
muskymike
muskymike's Avatar
Hi Robin, welcome. If you are redoing the shower, why not go all out and get rid of the pan and do a mud base. You can find info here.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 10-12-2005, 09:45 PM   #4
WackyStacker
Thanks for the input
Thanks for the input!
Question? Think the Mapei is the only way to go?
Regular mortar won't work or?
Again thank you!
As for doing a mud pan, I've been thinking about it. Feel a bit intimidated and was wanting a short cut because that old pan is in good shape but badly stained. The mud is not out as of yet but was trying to get some input on the tiling over the old idea.
Unread 10-12-2005, 11:31 PM   #5
Welcome Robin!
I might be reading this wrong, but I think Robin has a hollow fiberglass shower pan. And Scott thinks it's a mud pan.
Robin, please give me a clarification if you would. Thanks.
Unread 10-12-2005, 11:35 PM   #6
WackyStacker
it's fiberglass
YES, the pan is fiberglass
Unread 10-12-2005, 11:48 PM   #7
All bets are off. You can't tile over it.
Unread 10-13-2005, 04:40 AM   #8
scott anthony
Oppps yes I thought mud. No tile
Unread 10-14-2005, 02:17 PM   #9
WackyStacker
really?
OK
so all bets are off?
is there a reason?
I talked to a plumber 30 years experience on Kasamba and
he said it would work, of course you know I have to have more
than 3 people's advice that's why I'm here.
Now I don't know very much BUT.........
I know you must have a reason for saying that?
Could you please explain? I really need to hear it.
Robin
Unread 10-14-2005, 02:28 PM   #10
Splinter
Splinter's Avatar
There are several reasons. First, a fiberglass pan flexes too much. I know you said it feels sturdy, but that's just not going to cut it. Second, there's nothing to really adhere the tiles with that will last very long. Last, the drain isnt the type that you can unscrew to the proper height, as if it were a regular mudbed type drain.
Sorry, you either have to replace with another shiny white fiberglass pan, or build yourself a mudbed. They've talked many a DIY'er through it 'round here, Im sure with some bathroom experience behind you, you'll be able to do it too....
Oh, try not to listen to plumbers when it comes to tile work... (and Home Cheapo employees too )
Alex
Unread 10-14-2005, 03:04 PM   #11
muskymike
muskymike's Avatar
Hi Robin, what Alex said.
Musky Mike
Corrado Custom Tile
