Unread 04-15-2021, 07:24 AM   #1
SWB04
Overkill? Durock over wall studs: Add Construction Adhesive?
Question: Should I add Construction Adhesive (probably a poly version) on the wall studs before installing the Durock CBU with CBU screws?
Project: Quartz ledgerstone panels over Durock CBU, for an 18" high kitchen backsplash, (between upper cabinets and a granite countertop).
1) I realize that I probably could have just run thinset over the wallboard (per manufacturer's instructions). However, due to the weight of the stone, I prefer the stability of CBU with CBU screws (versus drywall screws) over a wallboard substrate. Plus, there were issues with the existing wallboard, including insufficient horizontal stud support.
2) Durock installation instructions (http://pdf.lowes.com/howtoguides/081099032585_how.pdf) are clear, i.e. CBU screws to studs, 16" OC maximum, etc..
3) I reinforced the wall with horizontal 2"x3" (i.e. non-structural) studs top and bottom (of the 18" backsplash area) between the 16" OC vertical studs, where I could. Where I could not, i.e. due to plumbing vent or drain pipes, I did the best I could (i.e. putting a stud above the pipe in the middle of the 18" area).
4) It bothers me that there will be places where there is no bottom or top horizontal support for the CBU between the vertical structural studs, to prevent flexing, because I have no way of getting a horizontal stud into those areas. Also, I left a 1 inch "tab" of wallboard top, bottom, and sides where I was able to, to be able to tape & thinset between wallboard and CBU. However, there's about 10' of area where there's a 1.5" gap below the back of the granite countertop, where the wallboard had already separated, (presumably because the drunk on the drywall crew was responsible for that joint). I will extend the CBU below and behind the countertop, and obviously, cannot tape that joint (without pulling out the countertop, cabinets, and destroying a bunch of stuff in the process).
5) Regarding the original question: Should I add a bead of construction adhesive to the studs prior to installing the CBU? The purpose would be to add strength, again, considering the weight of the 1/2" troweled thinset and quarts ledgestone panels that it will support? Or, should that CBU be free floating on the wall, with only the mechanical CBU screw fasteners for support, to prevent normal expansion and contraction from communicating through to the CBU? (Note: I'd like to use the poly version of Construction Adhesive, but may just use Liquid nails from Walmart, so I don't have to make the 1 hour trek into town to a big box store)
Thanks.
Scott
SWB04 is offline   Reply With Quote
Unread 04-15-2021, 11:15 AM   #2
Scott, if I understand what you did, I wish you hadn't done it.
The existing drywall would have been far more than adequate for installation of your ledgerstone panels.
Removing a section of that drywall and replacing it with CBU might sound like a positive step, but if you cannot provide blocking for all the new edges, I think it's a net negative.
But to your question, no, there is no need nor real advantage to using construction adhesive along with your mechanical fasteners in that application. It won't hurt anything if you've already done that, but it's not necessary.
Unread 04-15-2021, 12:42 PM   #3
SWB04
Thanks for the advice.
The dry wall wasn't contiguous. It was cut and separated (and therefore, flexed) at the countertop. I think that happened during the countertop installation, but as I said, I had a problematic drywall install (long story).
As far as CBU versus sheetrock behind stone, I realize that pro's would run this stuff over sheetrock seven days a week. I'm just not comfortable with that. I've seen so many snapped drywall screws (and in this situation, missing screws).
Blocking is a problem. I'll slip a backing in a couple of areas where blocking is weak, to meld the drywall to the CBU. I can't do that where I can't reach the drywall (below the countertop). There are three "cells" where I have vertical pipes preventing me from adding a block, and one that has a vertical 2x4 (i.e. leading edge of a rear wall) doing the same. It's just two very busy walls. I've got a third section yet to do, where the sheetrock is in better shape. However, I have to open part of that to do some electrical work, so I may or may not replace the sheetrock with CBU there.
I'm going to literally lay the CBU down on the kitchen island, and map out my screw pattern, to ensure I don't put a screw through an electrical line, drain, vent, water pipe, HVAC vent, or any other place that doesn't like screws (there are so many options to choose from! ).
(Also, don't worry, the countertop, stove, and cabinets will be covered before I install anything.)
Scott
Unread 04-15-2021, 04:04 PM   #4
Originally Posted by Scott
...to ensure I don't put a screw through an electrical line, drain, vent, water pipe, HVAC vent, or any other place that doesn't like screws...
Where's your spirit of adventure?
I would want blocking all across the bottom of the wall at the countertop, whatever it takes to get it there. An unsupported CBU edge span there would be in serious jeopardy of damage, I would think.
Unread 04-15-2021, 09:10 PM   #5
SWB04
Ahh, ya mean like when my plumber forgot to leak test a bathtub during construction, and I found out about that the day after drywall was complete, and the tub leak took out half my ceiling over my kitchen, the day before the kitchen cabinets where scheduled to be installed. That was after the 3 day drywall job required 13 days, and buried 15 electrical receptacles, including all the bath fans. Oh, and they nailed an electrical line in my garage, requiring surface mounting BX wiring, because we didn't have the time to tear out the double sheetrock ceiling. Of course, the drywall debacle was preceded by the ONLY city building inspector taking an unschedule two week vacation during the middle of the summer building season, with no relief. I'm kind of adventured out, by now. ????
Yeah, agreed on the blocking. I've done some creative things to make it happen. I finished the first section where there's a gap under the pipe (but I put blocking above it. It feels pretty solid. I think I can do something to mitigate the 3 other areas where blocking is difficult.
Let me finish with a rant.
I would have been a terrific major league pitcher. I mean, I have the memory of a gnat. I'll finish a project, and forget all about things I hated while doing that project. Take, CBU, for example. I love working with Hardieboard. I don't like cutting it, but I rarely have problems with breakage.
Now, contrast that to Wonderboard and Durock. They are made of some nylon netting and some sort of concrete akin to loose gravel. The attached picture show's a problem that started when I lifted the board, and it must have ended up on that corner, starting a slight fracture. It was barely noticeable, but I said, "Hmm, I've this movie before, and it's a horror film. Better be REAL careful with that corner so it doesn't break." So, after trimming another area and adjusting the receptacle opening a half inch, I carefully lift the panel in place. Perfect fit, all except that corner, which was at most, 1/8" too high. The entire six inch corner crushes. I had the rest of the board in, and thought if I could flatten the area, I'd cover with nylon mesh and reinforce with mortar when I'm sealing the gaps. I tapped a piece of 2x3 against it, and ... now it's dust. I can't cut and replace that corner. I doubt I can even repair it with tape and mortar, but I'm going to try. This stuff is just garbage. If you get every cut correctly, and install in nice, rectangular sections, sure, it'll work. If you have any problems at all with a corner, a punch out, whatever, the entire piece is basically trashed.
Hardie was $15 at the big box store, and Durock under $10. I knew I didn't like the stuff, but I didn't remember all the reasons why I hated it. Just like a MLB pitcher: Blow the game last night with a hanging curve ball, forget about it, gotta move on, there's another game tomorrow. Then go right back in the next night and throw that curveball again, to blow that game, too!
I HATE HATE HATE HATE Durock and Wonderboard.
I SWEAR I WILL NOT USE IT EVER AGAIN (like the last 10 times).
Scott
Unread 04-16-2021, 01:31 AM   #6
Originally Posted by SWB04
...Wonderboard and Durock. They are made of some nylon netting and some sort of concrete akin to loose gravel.
That “loose gravel” is physical damage, not a defect. Could be an impact from a forklift. Yes, Durock (and especially Wonderboard) require a little more work to cut, but that’s true about all sorts of different building materials. In your case, Hardi may have served you better.
If it makes you feel slightly better, I dislike the properties of Hardibacker’s incredible thirst for moisture, inability to bury its bottom edge in a shower mud pan, and inability to use it at exterior locations quite as much as you dislike Durock and Wonderboard. I prefer Durock over Hardi for the ease of obtaining great bond strength. And I also prefer Durock when adjoining 1/2” drywall, as Hardi is just too darn thin.
Unread 04-16-2021, 07:23 AM   #7
While horizontal blocking would be nice we're not talking about a high impact area, unless the cooks are prone to slamming a heavy food processor against the back splash.
Indeed, I would focus my attention on getting those electrical box mounting plates and pipe protector plates recessed into the studs so that their faces are even with the face of the studs. If you're using Hardie you might consider some drywall shims, which are 1/16th thick, to fur the Hardie out so it is even with the drywall.
IMO, natch.
Unread 04-16-2021, 06:49 PM   #8
SWB04
@KG (Bubba)
That "gravel" CBU damage was caused by me. Post rant, after I slept on this, I decided to just treat this like a drywall repair. Cut out an 8" x 6" rectangle, and replace, probably by overlapping the adjoining cell which has yet to be cut. Add a plywood backing plate to knit the drywall and/or CBU together. It's not as big a deal as I made it out to be.
I was mostly ticked at the time because I was trying to wedge the Durock into the "slot" where the damaged drywall sat between the granite countertop and studs, and it didn't compress to fit (concrete board doesn't compress, who knew?). While I was jockeying to cut down the board to fit, I damaged the opposite corner. I used Durock to build a fireplace surround last year, and I agree, it is easy to stick stone to it (with the help of a sticky mortar like Ardex x77).
@Dan
The electrical boxes will all need to sit proud to come even with the eventual Quartz ledger/stack stone, so I'm adding box extenders. The plates will sit close to even with the stone (which I may have to grind a bit to fit). That look worked out OK for the fireplace, and a prior backsplash project (see pix).
To all: As far as blocking in general, my goal is to ensure there is no more than 8" of space between two screws. So, where a vertical pipe (Or other item) prevents putting a horizontal blocking stud at the bottom of the backsplash, I'm adding several 6", 2x3 vertical blocks attached to structural studs, stacked, to close the 14.5" gap between studs to something closer to 10". It won't be near as strong as a proper block, but it'll help prevent flexing of the bottom of the backsplash, between the two studs.
For areas where I can reach the drywall (sides, under cabinets), I'm just handling blocking like I would a dry wall patch, i.e. putting 4"x6" or 10" x 6" plywood plate behind the joint. Secure with drywall screws to the drywall, and CBU screws to the CBU, to lock in the patch. The result is pretty strong.
So, adding the structural studs, the blocking, backing plywood plates, the 1/2" Durock, a whole bunch of CBU screws (plus a few drywall screws), 1/2" of combed mortar, and the back buttered 1"quartz panels, there's a lot of stability in that backsplash wall.
I'll post some progress pictures, uhhh, once I make some progress. ????
Thanks for your answers, and interest.
(Note: For some reason, there's no "reply" button after each post, so quoting and replying to person's post via HTML is problematic. That's why I referred to each person by "@".)
Scott
Unread 04-16-2021, 07:20 PM   #9
IN CASE
OF TORNADO
LAY ON
COUNTERTOP
TO BE
PROTECTED!
Yeah, the "Quote" button was removed years ago because it was severely overused. But take a look at this short YouTube video for easy instructions on how to do it.
Question about hanging durock -- lack of studs EvanNH Tile Forum/Advice Board 7 10-18-2009 07:11 PM
Blue seal (waterproof rubber membrane) over durock, overkill? newbieonhomes Tile Forum/Advice Board 4 07-27-2006 10:49 AM
is construction adhesive ok under durock? framer Tile Forum/Advice Board 3 05-09-2006 06:58 PM
Gonzo Overkill shower wall components Gonzo Overkill Tile Forum/Advice Board 7 06-21-2004 10:46 AM
Furring studs for Durock philip Tile Forum/Advice Board 3 03-25-2004 02:55 PM
