Unread 03-06-2021, 09:14 AM   #1
SpaceCadet
plywood over planks for vinyl
Technically not a tile question. I'm putting down 5/8 AC exterior grade plywood over 12x1 planks in a 2nd floor bathroom and the floor is going to get vinyl sheet. Too messed up and bouncy for tile. The planks are splitting and cut along the joists where someone needed to get at the plumbing.
Not as important here because it's just vinyl but what's the right way to attach the 5/8 plywood? Looked up some old posts: screw to the old planks, disagreement on glue so I'm leaving it out, and I saw something about screws long enough to protrude 1/4" out the bottom but that seems extra for this. 1-1/2 GRK R4 screws, 6" grid schedule, avoid the joists, predrill everything to avoid splitting the planks. Going to lay the plywood lengthwise along the joists to cover everything with 1 sheet, seems better than having a joint. Skim with planipatch or similar. Sound about right?
The planks are uneven. Do I shim the plywood with folded rosin paper or drywall shims to fill the voids?
Paul
SpaceCadet is offline   Reply With Quote
Any Thoughts on Waterproof Vinyl Planks? richk91 Tile Forum/Advice Board 3 03-13-2019 10:07 PM
Vinyl Planks in Bathroom jphustman Tile Forum/Advice Board 2 03-11-2017 11:44 AM
plywood between planks and hardie backer? benefit Tile Forum/Advice Board 8 11-12-2013 10:46 AM
Very confused on tileing over vinyl and plywood kmacht Tile Forum/Advice Board 9 04-03-2009 04:41 AM
Putting plywood over vinyl JanC Tile Forum/Advice Board 3 07-23-2008 12:37 PM
