Unread 01-19-2021, 10:34 AM   #1
JHarbinson
Residential Remodeling GC
Kerdi Board With Mud Pan
I apologize if this has been asked and answered but I wasn’t able to find the specific answer via search. I’ve always done my showers with a pvc pan, floated mortar bed and the cement board or floated walls. I’m contemplating using Kerdi board on the walls but was thinking due to cost I’d do a typical PVC and mud pan and use the kerdi board on the walls. Is that a thing?
Justin
JHarbinson is offline   Reply With Quote
Unread 01-19-2021, 10:51 AM   #2
It's a "thing" if you want it to be, Justin. No reason it wouldn't work if you wanna pay for it.
Unread 01-19-2021, 11:00 AM   #3
JHarbinson
Sorry for being “cute”. I guess what I’m wondering is would it be an okay solution to set the kerdi board in a traditional manner, having them inside the pvc pan and bottoms buried into the pan mud. Just like using cement board but better from what I understand. Or is it just smarter to build the whole thing with kerdi? I think what’s scaring me away from the latter is the high cost of kerdi.
Justin
Unread 01-19-2021, 11:09 AM   #4
I was not at all commenting on your choice of descriptive, Justin, my point was that if you wanted to do that it was simply your choice.
Unread 01-19-2021, 01:31 PM   #5
HilltopRehab
I'm looking at this option as well, for the purpose of a non-centered drain.
Apologies if you already considered it and are asking specifically about the use of a PVC liner and preslope technique, but Schluter has instruction and a youtube video for using Kerdi with a mud base - use a Kerdi drain instead of a clamping drain, build the mud base around it, sloped to the Kerdi board walls, and then waterproof with the Kerdi membrane. No PVC liner.
Steve
HilltopRehab is online now   Reply With Quote
Unread 01-19-2021, 06:09 PM   #6
Mathman
I won't pretend to try to translate Cx's words. He has MUCH more knowledge about these things as I do. But...(we all know where this is going) I think he is telling you of course you can do anything you want! But, Kerdi board and the kerdi system has instructions and procedures to make a successful install. If you can find this method of construction in Kerdi's manuals, then yes. If you can't find it then, also yes, you can do it. Just don't be surprised when it doesn't work. But, it could work!
I would guess kerdi board is as waterproof as cement board. So, $100 4X8 kerdi board instead of 2 or so 3 by 5 cement boards for 20 bucks or so.
Is that the plan?
Kirk
Mathman is offline   Reply With Quote
Unread 01-19-2021, 06:22 PM   #7
Kirk, KerdiBoard is waterproof, as opposed to CBU, which is not.
The KerdiBoard could, in fact, be used in lieu of a CBU in Justin's case. No qualifiers there. Nothing at all that I can see would prevent use of KerdiBoard in that application. All the manufacturer's requirements for installing the KerdiBoard would need to be followed, of course, including the requirements for waterproofing all the fastener penetrations and seams and such. It would work just fine used with a traditional receptor. I know of no requirement that it be used only in conjunction with a Kerdi receptor, although that would be the more common application.
That the same installation could be done far more inexpensively using a moisture barrier behind a CBU installation is certainly something I would recommend Justin consider, but that's not what he asked, eh?
Unread 01-19-2021, 09:11 PM   #8
If you're going to make a make a mud pan, why not use the Kerdi Drain, some Kerdi over it, and make the whole shower waterproof? The foam pan works if your floor is already flat and level, and is approximately the right size already. A mud pan is fine and many people prefer it. Then, you only need one mud bed, rather than two and the liner.
Unread 01-20-2021, 09:57 AM   #9
JHarbinson
That’s exactly how I have always done them. Waterproofing over studs, cement board into the pvc pan with the ends of the board buried in the mud. The reason for considering substituting kerdi board for cement board is the waterproof aspect of the board being buried in the mud, in the pan. I know there’s concern with some backer boards and having them into the pan (constantly wet) area.
Justin
Unread 01-20-2021, 02:47 PM   #10
I'm with Jim (Post 8). If I were going to use Kerdi-board on the walls, I would go ahead with a Kerdi drain and Kerdi over the floor mud. I see no advantage and not much cost savings in using a PVC liner and clamping drain.
Kerdi-Board and Cement Board Daniel1018 Tile Forum/Advice Board 3 09-19-2020 08:00 PM
Kerdi Band and Patches on Kerdi Board - Effect on 3x6 Subway Tiles? Rexiepo Tile Forum/Advice Board 18 03-29-2018 11:16 AM
Wall Tile Backer Board: Hardie, DensShield, Kerdi Board and others: Thoughts? machinemanjr Tile Forum/Advice Board 14 04-21-2017 04:40 PM
Green board? Cement board? Kerdi board? cburrows84 Tile Forum/Advice Board 7 03-21-2014 11:44 AM
Kerdi Board - Cement Board - Gypsum? PaulEdmonton Tile Forum/Advice Board 7 03-03-2013 07:35 AM
