Unread 01-14-2021, 10:51 AM   #1
mynewoldhome
I just bought my first (old) home and considering renovating the bathroom. Advice?
hi all. glad to join this forum and looking forward to learning as i go.
for the above referenced project i plan to pay a contractor.
right now we're doing a "freshening up" of the 2nd floor hallway bathroom. per the photos, you can see it needs it. interestingly the subway tile around the shower/tub looks pretty good.
the plan at the moment is to match the rest of the subway tile on the walls to the tile currently around the shower/tub area. we're also planning on replacing the floor. it appears the floor might be asbestos so we're contemplating just tiling over it vs. removing it entirely. would be curious what the board thinks about this idea?
i guess i'll need to pay a plumber to remove the hot water radiator so they can get behind it properly?
lastly, any decent (but not expensive) tile to look at? i've been looking at datile, american olean, etc.
anything else that looks off/or i should consider?
thanks again and looking forward to being a part of this community!
Matt
mynewoldhome is offline   Reply With Quote
Unread 01-14-2021, 12:46 PM   #2
Hi Matt, welcome. If you plan to tile other walls and want the new tiles to tie in with the old, the first thing I would do is bring some sample tiles home to make sure they are the same size. The A-4200 mud type bullnose you have is still available but matching the exact shade of your old tiles might be hard to do.
Unread 01-14-2021, 01:26 PM   #3
mynewoldhome
thanks Davy.
my issue now is that since i mentioned the tile could contain asbestos, my contractor backed out saying it's now a liability...
what should i do next? how do i find a contractor that's comfortable and able to handle old asbestos tile properly?
thanks!
Matt
Unread 01-14-2021, 01:51 PM   #4
I've never done it but it would probably be best to go over the floor tiles with cement board. But, lets get the opinion from others first. Years ago, before we knew better, we removed a lot of those old asphalt tiles. I'm not going to tell you to do it though. I would want to make sure they are all bonded well and that there's no soft (rotten) places in the floor. Can you get to the space under the floor, maybe a basement to check it out?
NEWB needing advice, 50s home bathroom remodel Big Tom Tile Forum/Advice Board 3 04-17-2011 09:22 PM
Renovating the Bathroom of Fail AngryMarmot Tile Forum/Advice Board 30 08-15-2010 04:02 PM
Renovating Ensuite Bathroom JD Hart Tile Forum/Advice Board 4 05-24-2009 12:07 PM
Bought a home w/ slate shower hoppejm Tile Forum/Advice Board 3 03-19-2008 09:24 PM
Renovating a 50's bathroom? hartmark Tile Forum/Advice Board 2 10-21-2003 08:06 PM
