Unread 12-29-2020, 11:54 AM   #1
Mathman
Help with Moen Valve
I have an older moen valve that is only flowing hot water. I just replaced a water softener that had an unknown leak and there was green gook in the pipes. Cut out some and poured some bleach to clean out and of course stuff was flowing into the house. Had to clean the faucet aerators.
I guessing something bigger blocked the cold water. I remove the valve and still only hot water flows so I know it isn't the valve.
Does anyone know how I can possible get this to flow again?
Picture of the valve.
Kirk
Mathman is offline   Reply With Quote
Unread 12-29-2020, 01:24 PM   #2
diydanny
I would turn off the water to that valve, relieve pressure, then remove the cartridge(s) to flush out or replace.
It looks like a single stem cartridge to me but search your model. You remove the spacer(s), then pull up on that thin upside down brass horseshoe retainer to remove, then you can pull out that center cartridge.
diydanny is offline   Reply With Quote
Unread 12-29-2020, 06:01 PM   #3
Mathman
Thanks, I used the wrong language. I have removed the cartridge and still no flow from the cold water side. I was not sure I could take out the side parts. Which I now know are called stop check valves. I hope to remove the cold side tomorrow and see if I can clear what is blocking it.
Kirk
Moen shower valve Emil Volk Tile Forum/Advice Board 10 07-23-2020 12:52 PM
Moen 3372 Diverter Valve Mike1324 Tile Forum/Advice Board 7 06-28-2018 10:15 AM
Moen 295 ioDigital Danj67 Tile Forum/Advice Board 1 03-31-2010 09:51 PM
Moen ExactTemp Valve jjscavo Tile Forum/Advice Board 3 05-26-2006 09:21 AM
Removing Moen tub valve bbh03 Tile Forum/Advice Board 9 12-26-2005 09:53 PM
