Unread 04-16-2021, 01:31 PM   #91
Originally Posted by Matt
Schluter says you can lay Kerdimat on a mud pan as soon as it’s safe to walk on. Mapei says the mud is OK to walk on after 16h.
Well, if you're using Schluter's membrane and MAPEI's mortar, I think you have your answer, non?
Unread 04-20-2021, 05:58 PM   #92
MAPEI - Technical Service
Company Representative
Sorry I'm late to the party gang. I haven't seen my computer in the last handful of days.
To clear up the lath/no lath debate; in most unbonded mortar bed scenarios, we want expanded metal lath or welded wire mesh at approximately the middle of the mortar bed.
Now, TCNA recently updated their curbless shower details with a statement off to the side that reads: "For mortar beds over 65 S.F. wire reinforcing is required."
This is a good rule of thumb, as our opinion is that most smaller shower pans are not large enough to really require reinforcement. That's not to say no shower pan ever needs reinforcement, it is just more of a case-by-case basis. We would not be surprised if that that above statement found its way to other shower receptor details in the coming editions of the TCNA handbook.
Holden
http://www.mapei.com/US-EN/
Unread 04-20-2021, 06:08 PM   #93
That expanded metal lath in that statement is the part I took issue with, Holden. Yes, you would want welded wire in the vertical center of an unbonded mud bed, but expanded metal lath use the same way? You are not concerned that you are creating a shear plane rather than reinforcement?
Unread 04-20-2021, 06:21 PM   #94
CX,
I'll dig into it some more tomorrow with the powers that be; but we have made this recommendation for years with no issues that I am aware of with it.
Holden
Unread 04-25-2021, 08:54 AM   #95
MesaTileworks
Question about cure time before grouting:
I’ve got 3x6 ceramic subway tile on shower walls and 2” hex floor tile that I’m finishing up in the next couple of days. Been setting the tile with Mapei Ultraflex mortar (except for a few areas where stone has been laid over kerdi using unmodified as per Schluter recommendations).
Mapei instructions say 16-24 hours for foot traffic on the Ultraflex but I just had an inconclusive convo with a Mapei rep about minimum cure time on either or both mortars before grouting. Any recommendations? Is 16h enough? 24? More?
I’ve mostly used the “OK to grout the day after setting tile” rule of thumb... we are rushing to meet a deadline and don’t want to slice it too thin—but do want to grout as soon as possible.
I do have some rapid set on site so that’s also an option.
MesaTileworks is offline   Reply With Quote
Unread 04-25-2021, 09:35 AM   #96
MesaTileworks
(On past projects I’ve often left some extra cure-time out of a probable over-abundance of caution, but this one has a tight deadline...)
Unread 04-26-2021, 08:13 AM   #97
Jason@mapei
Jason Cantin Mapei Technical rep
Jason@mapei's Avatar
Mapei Mortar
When mortar dries and cures it is releasing the water of convenience that is in the mortar, It usually does so top and bottom. when installing over a membrane and using porcelain tile this will retard the release of extra water, so cure time will vary. This is especially a problem with large porcelain tile. Each application will also be affected by ambient conditions.
Jason
Jason@mapei is offline   Reply With Quote
New house, old bathrooms edeichert Tile Forum/Advice Board 2 05-07-2018 04:12 PM
Old house kitchen reno hmccull Tile Forum/Advice Board 7 08-13-2009 08:38 AM
Help, new house with shower problems!! MAXTBSS Tile Forum/Advice Board 4 06-20-2007 05:48 AM
Tile problems in new house Danrules Tile Forum/Advice Board 16 01-16-2007 01:17 PM
New house shower tile problems AL1 Tile Forum/Advice Board 3 07-28-2006 09:01 AM
