Unread 03-02-2020, 07:55 AM   #1
groomerz
Opinion on this tile work
A local contractor was pitching his work with this photo. What do you like or not like?
groomerz is offline   Reply With Quote
Unread 03-02-2020, 08:33 AM   #2
jerrymlr1
Tile work with the granite looks good. The caulk joints are a little wider than I would like. I would also run the tile on the bench top perpendicular or in line with the edge and face of the bench as opposed to perpendicular with the walls. Did the contractor specify a waterproofing and shower construction method?
Jerry
Unread 03-02-2020, 08:54 AM   #3
groomerz
No he didn’t specify waterproofing method.
Unread 03-02-2020, 09:03 AM   #4
groomerz
I see what you mean by the seat grout lines parallel and perp to the edge would look better
The large niche caught my eye
Should have built out that left side to avoid small unsquare sliver in back and make the niche line up better in left side. Small pieces bad and are easier to spot unsquareness
Unread 03-02-2020, 10:26 AM   #5
Were you fixin to hire him?
The work looks very neat.
I would have done my best to talk the homeowner out of using natural stone in the shower though.
The critical question is the waterproofing method used. The prettiest tile work in the world is useless without solid waterproofing.
Unread 03-02-2020, 11:29 AM   #6
jerrymlr1
Yes the niche could have been easily done with full pieces. I noticed the L cuts but missed the slivers in back.
Jerry
Unread 03-02-2020, 01:40 PM   #7
groomerz
I’m interested in your opinion about not using natural stone in a shower can you explain.
Unread 03-02-2020, 02:09 PM   #8
rmckee84
rmckee84's Avatar
Natural stone is inherently unpredictable. Many times it can contain iron deposits (resulting in rust), discoloring, and overall poor wearability. These are not constants, but are common issues among many others
Ryan McKee
Unread 03-02-2020, 03:02 PM   #9
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
I think it's ugly but the craftsmanship looks good.
Travis
It's just a clever handle.
Unread 03-02-2020, 05:38 PM   #10
Fast eddie part deux
Should have raised the niche an inch to align with upper joint.
Maybe added a contrasting horizontal stripe to break up the field.
Ed
Fast eddie part deux is offline   Reply With Quote
Unread 03-02-2020, 05:48 PM   #11
What Ryan said plus;
Many natural stones are porous to the point they absorb water and become darker. No amount of sealer will stop this from happening.
Unread 03-02-2020, 06:20 PM   #12
groomerz
Thx
Opinion and Advice please on sketchy tile work? pokerliz Tile Forum/Advice Board 24 11-09-2016 12:42 AM
Tile saw opinion GHR Tile Forum/Advice Board 11 06-07-2012 04:57 PM
Looking to barter some web work for some tile work (Cleveland area) DMZadony Computer Training 7 09-29-2010 12:40 PM
need opinion on contracted tile work that looks unsatisfactory 1cbtengr78 Tile Forum/Advice Board 10 02-21-2010 08:54 PM
tile saw opinion Fiasco Tile Forum/Advice Board 10 06-27-2007 10:53 PM
