Unread 03-22-2019, 07:12 PM   #1
lati_cz
michal
safe tile removal
Glass company botched enclosure install. Cracked tile under upper hinge, I need to replace it. Tile is next to window, so has schluter trim on both sides, it's approx. 12 x 12" piece. Tile is on Versabond, Redguard, tile board. Installed approx. 4 months ago.
Any advice how to remove Safely appreciated.
Michal
lati_cz is offline   Reply With Quote
Unread 03-22-2019, 07:36 PM   #2
rmckee84
rmckee84's Avatar
Protect and cover everything below, go at it with a hammer and punch to break it up. Make sure and cut the surrounding grout lines.
Ryan McKee
Unread 03-23-2019, 06:37 AM   #3
The smaller the pieces, the easier it will come out. You might also cover it with masking tape to keep the smaller pieces from going everywhere. Maybe if you're lucky, someone will have done a crappy job of setting it.
You'll probably still have to redo the waterproofing layer. Is it at or above the level of the shower head?
Unread 03-23-2019, 08:24 AM   #4
lati_cz
michal
it's above water line.
the guy who install the tiles always backbutter and check coverage....
I got dremel tool to cut the grout lines (16") first, than I will try to brake the tile in small pieces. I am bit nervous about it.
Glass company (established, did always good installs for 10 years for me) sent 2 rookies for initial install, they screwed up, installed hinges out of plumb. They asked me to remove tile. I said no. They had to have new, larger hinges fabricated to cover holes. When they install 2nd, time, tile cracked....
My customers are without the shower for 8 weeks.....
Michal
Unread 03-23-2019, 12:39 PM   #5
The Schulter trim could make it tough. Hopefully you won't bend them.
Unread 03-23-2019, 04:16 PM   #6
My guess would be that it'll peel the Redgard off the wall board.
What is it, Durock, sheetrock, etc.?
safe way of removing tile from wall Canaris Tile Forum/Advice Board 1 03-07-2018 05:22 PM
When is it safe to lay tile after wetting concrete? Bob_J Tile Forum/Advice Board 9 09-28-2005 06:45 PM
How to calculate if span is safe for tile jasontking Tile Forum/Advice Board 21 11-17-2004 10:32 AM
so, are we safe? flatfloor Computer Training 4 07-17-2004 12:37 PM
When is it safe to use? kbanks226 Tile Forum/Advice Board 1 06-16-2004 06:21 AM
