Unread 03-21-2019, 08:45 AM   #1
lati_cz
michal
trimless door installtion
I am doing home remodel, modern style. HO want me to do, resp. like my ideal of "trimless" door installation and baseboards flush with drywall.
They want to achieve this look
https://www.youtube.com/watch?v=p5xj6XpHkrg&t=207s
http://www.drywalltrims.com/product/STR-025-063.html
Looks like we will be using flat door (painted grade) in custom jambs 1" thick douglas fir (stained grade) as well as baseboards.
Looks Pita, but straight forward. I always wanted to do it, customer is detailed oriented, must be Perfect...
Anyone here has experience with it?
Michal
lati_cz is offline   Reply With Quote
Unread 03-21-2019, 04:34 PM   #2
PC7060
PC7060's Avatar
I’ve never used is but should be a very nice look. Tricky bit will be maintain this consistent reveal like in the video by Matt Risinger. Glad to see you are using the aluminum bead; vinyl would be a bear.
As a tile pro, I imagine you have experience cutting aluminum edging simaulter to Schluter jolly.. You can get a very nice miter but man those chips are painful. Full face shield is essential.
Good luck and share pics of your experience.
Unread 05-16-2019, 10:05 PM   #3
lati_cz
michal
This type of installation is time consuming and shows every little imperfections. There's no room for caulk... Every 1/16" counts and starts with framing... I will post some pictures when I am done.
Michal
Unread 06-06-2019, 10:16 PM   #4
lati_cz
michal
Few pictures. I am done. I am glad it was just few doors.....
Michal
Unread 06-06-2019, 10:42 PM   #5
lati_cz
michal
Few tips:
Use 5/8" drywall. I checked all framing with straight edge, planed down bowed out studs, but after drywall was installed, some areas were proud. I had to cut out few sections and replaced with 1/2" drywall. Can't be done if 1/2" drywall is used. 5/8"is also more stiff.
Use 1/2" reglet trim. 5/8" drywall works with 1/2" trim, you can't see difference.
Foam around door jambs - lights goes through between jambs and reglet trims.
Charge T&M
Michal
Unread 06-06-2019, 10:57 PM   #6
jwmezzanotte
jwmezzanotte's Avatar
Very nice!
I’ve seen that look installed before, I’m sure it’s tedious.
Have you seen Ariavents? Might save you some work next time, they now make a drywall version with corner bead. Has a similar look once finished.
I’ve used a couple of them, very slick!
https://www.ariavent.com
Unread 06-07-2019, 09:22 PM   #7
Gozo
How’s that do with seasonal changes? In my area, the difference in humidity from winter to summer causes some significant changes in wood dimensions even with indoor climate control. I’d expect to see some gapping or buckling depending on when in the cycle it was installed, at least here. It does have a clean look, but close tolerance to install.
Jeff
Unread 06-08-2019, 04:55 PM   #8
lati_cz
michal
gapping or buckling on what?
Michal
Unread 06-08-2019, 07:21 PM   #9
PC7060
PC7060's Avatar
Nice work! Appreciate the tips.
Unread 06-08-2019, 08:07 PM   #10
Gozo
It looks in the picture that there’s a metal trim around the wooden door jamb. I was referring to the affects of the different expansions of the dissimilar materials. Very likely not enough to be of any concern, but I can’t say for sure.
Jeff
Countertop installtion with Ditra: needed advice Vern717 Tile Forum/Advice Board 1 11-17-2008 03:07 PM
Pre-installtion efflorescence..or something else? ehuesman Tile Forum/Advice Board 2 01-01-2008 12:43 AM
Kerdi installtion ordering question jgwufgator Tile Forum/Advice Board 2 05-16-2007 03:57 PM
tiling area beneath door jamb on front door jepthng Tile Forum/Advice Board 1 09-24-2006 03:27 PM
L/897 Deflection - Seek Specifics on Building Subfloor for Stone Tile Installtion bradesp Tile Forum/Advice Board 3 02-23-2005 04:36 PM
