Unread 04-23-2010, 09:42 PM   #1
m_westall
remove grout
Hello,
We have some tile bowing in our shower. I think we have drywall behind the tile. All of our bath walls are tiled from floor to ceiling and the tile is no longer for sale at the store we bought it at. The tile grout is missing in some areas where the bowing is taking place. As a band aid we are planning to remove the grout, regrout and seal the grout. Attached is a picture of the bowed tile but you cannot tell it is bowed in the picture. Does anyone have any good ways to remove the grout inbetween the tiles before we regrout?
Mark
Mark
m_westall is offline   Reply With Quote
Unread 04-23-2010, 10:34 PM   #2
Deckert
What kind of tile is it? Is it moisture sensitive? Whats causing the "bowing"?
I guess what I'm getting at is wanting to know why there is a problem before I spent any time or money trying to fix it.
A grout saw or a dremel/fein/etc with the proper grout blade would remove the grout.
Brannigan
HeenanGC.com
Unread 04-23-2010, 10:43 PM   #3
oakview
Retired Moderator - Owned by two rescued greyhounds
oakview's Avatar
Mark, is this the same shower you remodeled in this thread? Just askin'
Drywall behind tile is a no-no unless the shower was built using the Kerdi system. If it wasn't, you have bigger issues at hand than can be solved with a simple re-grout. Take a tile off the shower wall and see what's behind - if it is drywall, your band-aid proposal will not do much, if anything. Sounds like the tile is starting to separate from the wall, and I would wager that the drywall is moldy and deteriorating, and the tile might have set with mastic, also a no-no in wet areas. If that's the case, your shower needs to be re-built using correct methods.
::DaveG::
The Tile and Stone Magazine for Consumers!
New to the Forum? Read this! :.: Click here to add your name to your signature.
"If you don't have time to do it right, when will you have time to do it over?." -John Wooden
oakview is offline   Reply With Quote
Unread 04-23-2010, 10:53 PM   #4
m_westall
No this is not the bath I remodeled. I am aware that the drywall is not a good choice for tile backing. The tile is not water absorbing. What happened is the grout started coming loose and that is how the water got behind the tile. I am hoping removing the grout and regrouting will buy me some time. The shower is about 7 years old.
Mark
Unread 04-23-2010, 10:56 PM   #5
m_westall
I see the grout saw is a hand tool. We will try this.
Mark
Unread 04-23-2010, 11:41 PM   #6
trecile
I don't think that is the problem. Whether or not the grout is "loose" water can and will penetrate grout.
Terri
trecile is offline   Reply With Quote
Unread 04-24-2010, 01:14 AM   #7
m_westall
Would a grout sealer help?
Mark
Unread 04-24-2010, 02:02 AM   #8
tileman2000
New England Tile Man
tileman2000's Avatar
Hi Mark,
Drywall is your biggest problem in the shower.
Regrouting and sealing would only be a temporary fix.
Michael
Unread 04-24-2010, 02:04 AM   #9
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
doubt it, damage is done
Jim
Jim Farrell Tiler is offline   Reply With Quote
Unread 01-13-2019, 10:04 PM   #10
m_westall
Lower shower tiles pulled
While washing the shower today, my wife noticed the tile flexing in and out. I removed the whole lower row of tiles and I’m wondering what the best way to fix it without redoing the whole shower. The shower construction is backing paper, drywall then tile. Any suggestions to save the shower?
Mark Westall
Mark
Unread 01-13-2019, 10:16 PM   #11
Radas
Tile Newbie
The tile is directly over drywall in your shower? Or is the tile over a membrane bonded to the drywall? If directly on drywall, rip it all out, there is no way to fix that install. Tile over drywall is never ok in a shower because tile is not waterproof and neither is drywall, hence the wall moving.
Sent from my SM-G930P using Tapatalk
Ali
..a new excuse to hoard tools
Unread 01-13-2019, 11:22 PM   #12
m_westall
That is correct, the tile is directly over the drywalll. Problem is all the bathroom walls are completed with tile. I would either have to very carefully remove all the tile without breaking it or remove around the shower only and replace with tile that looks different than all the other tile. I can redo the shower with kerdi but I really don’t want to put different tile.
Mark
Unread 01-13-2019, 11:30 PM   #13
You might be able to get the drywall off of the tile, but expect to break a couple in the process.
Cut the grout out between the tile. cut through the drywall to pull them out piece by piece. Place them in a pan of water, let them sit for long enough to soften the drywall paper, carefully strip off the drywall, clean up the tile. Lots of work, may not be successful.
You'd need to cut out beyond the shower confines to then be able to get new waterproofing or at least a moisture barrier up on the wall. Depending on where the next stud is and where the tile ends, you might need to install a new stud so the edges there would be supported.
Lots of work, if you have no spare tile, and you break even one. Fate would have it that it's the last one.
Unread 01-14-2019, 07:00 AM   #14
Humphreyp
Mark....
I see rotting studs and mold in your picture?
Take it down. Pick a spot to end just past the shower frame. Hopefully theres already a stud where the frame attaches. If not....add one. Water proof past the frame...have her go pick tile that will compliment everything.
Just remember: dont overthink. And always ask questions.
Pat
Humphreyp is offline   Reply With Quote
Unread 01-17-2019, 10:33 AM   #15
groomerz
Just curious how old is that install is.
groomerz is offline   Reply With Quote
Lower Level Shower Remodel Alan_Fz Tile Forum/Advice Board 2 03-04-2008 02:11 PM
Shower pan lower than slab? Dan_the_man Professionals' Hangout 6 03-17-2006 09:51 PM
Lower tiles in shower popping jgv Tile Forum/Advice Board 15 09-20-2005 06:16 PM
Tiles pulled paper off old backerboard jthoni Tile Forum/Advice Board 2 06-16-2005 06:27 PM
Why Are Shower Ceilings Lower? bdoon Tile Forum/Advice Board 16 02-24-2005 11:54 AM
