Unread 01-25-2018, 01:19 PM   #1
groomerz
Backsplash batten board
Installing 2x4 wavy edge subway tiles on 12x12 sheets with an uneven counter top. Small cabinet on left of range is 1/4" lower but level just a different level so granite bridge behind slide in range drops 1/4" in 30" Plan was to screw batten board start second row level and later cut in first row. Went into my garage to rip some batten boards and came across some fiber board drywall shims 48"x 1 1/2 ". Doubled them up and installed with stapler quick and easy for a backsplash and you can manipulate them a bit if needed
groomerz is offline   Reply With Quote
Unread 01-25-2018, 01:27 PM   #2
groomerz
And a pic of other side of galley kitchen
Unread 02-01-2018, 10:15 AM   #3
groomerz
New backsplash mounting rods with silicone thoughts
Just finished kitchen backsplash and mounted some accessory rods I didn't want to drill tiles. I used clear silicone on mounts with 2 small dabs of hot glue Pressed to tile hot glue instantly solid hold allowing silicone time to cure. After 3 days installed rods and hung some coffee mugs. Seems really solid mount do you think it will hold
Unread 02-01-2018, 11:55 AM   #4
Welcome back, Shawn.
Either it will or it won't, but that's just a guess. I'd prefer some mechanical fasteners were it mine.
Unread 02-01-2018, 06:31 PM   #5
john619
you could always mount the hanging rod to the underside of the upper cabinet and not have to run fasteners thru the tile.
john
Unread 02-02-2018, 01:26 AM   #6
Why the hesitation to drill through the tiles?
Unread 02-04-2019, 10:28 AM   #7
groomerz
So I wanted to update rods are still hanging tight after 1 year
My reasoning for not drilling is my wife has tendency to change things up and didn’t want to make holes
Unread 04-08-2020, 06:20 AM   #8
groomerz
Still holding
Tec Skillset Silicone Caulk vs Tec Accucolor Silicone Sealant adellecave Tile Forum/Advice Board 3 12-24-2016 06:38 AM
How to remove silicone based sealer so i can use silicone caulk in shower lccavender Tile Forum/Advice Board 7 10-29-2015 05:19 PM
Silicone or Latex on granite backsplash? jvarnes Tile Forum/Advice Board 2 06-25-2007 10:47 AM
Kitchen Backsplash Problem and Silicone Caulk CT residue Civitas Tile Forum/Advice Board 12 08-01-2006 10:26 AM
silicone sealer between granite and marble backsplash kpgclark Tile Forum/Advice Board 3 02-22-2004 03:40 PM
