Unread 09-01-2016, 07:26 AM   #1
w1nk5
Stained grout
I just installed some natural stone tile for the first time. I filled instructions and cleaned the tile and grout with a water/vinegar solution. The first cleaning went fine. The grout returned to original color. The second cleaning, 2 days later, it still looks wet or stained in some areas.
An image is attached.
How can I resolve this? Please help!!
Bill
w1nk5 is offline   Reply With Quote
Unread 09-01-2016, 09:03 AM   #2
Welcome to the forum, Bill.
Could you tell us a few things about the grout and how you installed it?
What brand of grout is it?
How long after the grout was installed did you use vinegar on it?
What ratio of vinegar/water did you use?
What brand of thinset mortar did you use, and was it gray or white?
What is the substrate, as in the tile backer, or is the stone directly over the subfloor?
Unread 09-01-2016, 10:54 AM   #3
Premier Designs
And what type of natural stone is that?
www.premierdesigns4u.com
Premier Designs is offline   Reply With Quote
grout stained rhbuilds Cleaning, Restoration and Sealing 6 05-15-2012 08:03 AM
Stained Grout Briyon Cleaning, Restoration and Sealing 2 04-04-2011 11:44 AM
Stained grout dave99 Cleaning, Restoration and Sealing 5 03-25-2011 03:13 PM
White wall grout has stained colored floor grout mizkriz Cleaning, Restoration and Sealing 2 01-26-2007 08:47 PM
Grout stained tub bgronski Cleaning, Restoration and Sealing 3 11-04-2004 02:54 PM
