Unread 01-17-2019, 12:06 PM   #16
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
there is a post on JB forums from someone saying you dont need waterproofing ....seems he was wrong
Jim
Jim Farrell Tiler is offline   Reply With Quote
Unread 01-17-2019, 12:46 PM   #17
Radas
Tile Newbie
Just noticed that the OP has been here in the past and not taken advice regarding his tile on drywall shower assembly.
I think the grout falling out and tiles 'flexing' back in 2010 was a clear indication that there was a problem with the installation. I am surprised that the shower has lasted this long and not fallen through what's left of the subfloor.
Sent from my SM-G930P using Tapatalk
Ali
..a new excuse to hoard tools
Unread 01-17-2019, 04:37 PM   #18
jlbos83
Really Cool Weekend Warrior
There's only one answer to this shower. And you already know what it is. As far as matching the tile, don't try! Put and accent piece or some kind of trim in, and make it look like a feature. Better than rotting the house out.
It's a DRY heat!
jlbos83 is offline   Reply With Quote
Unread 01-17-2019, 07:43 PM   #19
Technically, the only part that needs to be waterPROOF is the pan...the rest needs to be built so moisture won't cause damage...drywall, unprotected, doesn't cut it.
Unread 01-19-2019, 12:23 AM   #20
groomerz
So this would be a great example of what happens when you put tile over drywall in a shower without red guard, ditra. I wonder if the drywall had no gap and was resting on pan
groomerz is offline   Reply With Quote
Unread 01-19-2019, 01:29 AM   #21
There are only two companies that have tested their waterproofing for use over drywall and both of them are sheet membranes, not liquid. RedGard can be used over cbu, but not drywall.
Ditra is not designed for use in a shower, and shouldn't be used there...the pockets could collect water and not drain. Kerdi is needed there.
Unread 01-19-2019, 07:33 PM   #22
JITILE
Everyone here is right about the repair only being temporary but if you remove the tile so that all the damaged drywall is gone, and carefully soak or sand off the backs of the tiles to clean them I would thoroughly dry out the area behind the tile replace the drywall with cement board, Force some exterior grade construction adhesive between the cement board and clean cut drywall , then carefully replace the tile with thinset..... realistically if the tile has been there for some time before this happened you should actually be able to get at least that much more time out of it with doing a good repair, even though the installation wasn't originally done properly
James
JITILE is offline   Reply With Quote
Unread 01-19-2019, 07:35 PM   #23
JITILE
And also rolling on some redgard or hydro ban wouldn't be a bad idea either
James
Unread 01-19-2019, 08:19 PM   #24
You could use KerdiBoard or WediBoard instead of cbu and have waterPROOF walls rather than water resistant ones.
Lower Level Shower Remodel Alan_Fz Tile Forum/Advice Board 2 03-04-2008 02:11 PM
Shower pan lower than slab? Dan_the_man Professionals' Hangout 6 03-17-2006 09:51 PM
Lower tiles in shower popping jgv Tile Forum/Advice Board 15 09-20-2005 06:16 PM
Tiles pulled paper off old backerboard jthoni Tile Forum/Advice Board 2 06-16-2005 06:27 PM
Why Are Shower Ceilings Lower? bdoon Tile Forum/Advice Board 16 02-24-2005 11:54 AM
