Go Back   Ceramic Tile Advice Forums - John Bridge Ceramic Tile > Tile & Stone Forums > Reference Liberry :-)
Closed Thread
Unread 01-27-2003, 01:26 PM   #1
flatfloor
"da Leveler"
flatfloor's Avatar
Mold
This is an excerpt from a thread about mold. The auther is a member and an official with the Dallas Housing Authority.
4. so what works? According to the instructor of the mold class I attended, try a spray bottle with the following in it:
1/2 gal. white vinegar
1/2 gal. hydrogen peroxide-common peroxide available from your drugstore
1 cup boric acid
keep closed tightly
mix well - use in a spray bottle on a dry surface.
Shake well and spray area well. The vinegar/peroxide kills active live mold and the boric acid keeps them that way. (Note: uncapped peroxide loses it's oxygen molecules to the air when not capped tight and becomes H2O [water], so keep this solution in a bottle that can be capped off tight).
Instructor stated that boric acid works on mold bodies like it does on roach bodies - cuts them and they bleed to death because they cannot "coagulate" (snakes and snails and puppydog tails).
I guess we all know that there are some very beneficial molds, too.
One last note on the above solution. This solution will not "bleach" out the mold stain. After mold is under control, then you can bring out the bleach and whiten the mold stains.
For all you shower lovers!!!!
Slowbaker
Jim Buckley
This is as bad as it can get, but don't count on it.
Tile Calculator
New Here? Read this!
flatfloor is offline
Unread 02-08-2006, 12:25 PM   #2
bbcamp
About Mold
This was posted by one of our members, jfonta77. I think you'll find it usefull.
ABOUT MOLD
What is it? Molds are simple, microscopic organisms, found virtually everywhere, indoors and outdoors. Molds can be found on plants, foods, dry leaves, and other organic material. Molds are needed for breaking down dead material. Mold spores are very tiny and lightweight, and this allows them to travel through the air. Mold growths can often be seen in the form of discoloration, ranging from white to orange and from green to brown and black. When molds are present in large quantities, they can cause allergic symptoms similar to those caused by plant pollen.
Should I be concerned about mold in my home? Yes, if the contamination is extensive. When airborne mold spores are present in large numbers, they can cause allergic reactions, asthma episodes, infections, and other respiratory problems for people. Exposure to high spore levels can cause the development of an allergy to the mold. Mold can also cause structural damage to your home. Similarly, when wood goes through a period of wetting, then drying, it can eventually warp and cause walls to crack or become structurally weak.
What does mold need to grow? For mold to grow, it needs:
food sources - such as leaves, wood, paper, or dirt
a source of moisture
a place to grow
Can mold become a problem in my home? Yes, if there is moisture available to allow mold to thrive and multiply. The following are sources of indoor moisture that may cause problems:
flooding
backed-up sewers
leaky roofs
humidifiers
mud or ice dams
damp basement or crawl spaces
constant plumbing leaks
house plants -- watering can generate large amounts of moisture
steam from cooking
shower/bath steam and leaks
wet clothes on indoor drying lines
clothes dryers vented indoors
combustion appliances (e.g. stoves) not exhausted to the outdoors
CAUTION: If you see moisture condensation on the windows or walls, it is also possible that you have a combustion problem in your home. It is important to have sufficient fresh air available for fuel burning appliances, such as the furnace, water heater, stove/range, clothes dryer, as well as a fireplace. A shortage of air for these appliances can result in back drafting of dangerous gases such as carbon monoxide into the home. To prevent back drafting of air, you need either open vents or a ventilation system that brings fresh air into the home to replace air that is exhausted out. Have your local utility company or a professional heating contractor inspect your fuel-burning appliances annually.
HEALTH EFFECTS
How am I exposed to indoor molds? Mold is found everywhere, indoors and outdoors. It is common to find mold spores in the air of homes and growing on damp surfaces. Much of the mold found indoors comes from outdoor sources. Therefore, everyone is exposed to some mold on a daily basis without evident harm. Mold spores primarily cause health problems when they enter the air and are inhaled in large number. People can also be exposed to mold through skin contact and eating.
How much mold can make me sick? It depends. For some people, a relatively small number of mold spores can cause health problems. For other people, it may take many more. The basic rule is, if you can see or smell it, take steps to eliminate the excess moisture, and to cleanup and remove the mold.
Who is at greater risk when exposed to mold? Exposure to mold is not healthy for anyone inside buildings. It is important to quickly identify and correct any moisture sources before health problems develop. The following individuals appear to be at higher risk for adverse health effects of molds:
Infants and children
elderly
immune compromised patients (people with HIV infection, cancer chemotherapy, liver disease, etc.)
pregnant women
individuals with existing respiratory conditions, such as allergies, multiple chemical sensitivity, and asthma.
People with these special concerns should consult a physician if they are having health problems.
What symptoms are common? Allergic reactions may be the most common health problem of mold exposure. Typical symptoms reported (alone or in combination) include:
respiratory problems, such as wheezing, and difficulty in breathing
nasal and sinus congestion
eyes-burning, watery, reddened, blurry vision, light sensitivity
dry, hacking cough
sore throat
nose and throat irritation
shortness of breath
skin irritation
central nervous system problems (constant headaches, memory problems, and mood changes)
aches and pains
possible fever
Are some molds more hazardous than others? Allergic persons vary in their sensitivities to mold, both as to amount and type needed to cause reactions. In addition, certain types of molds can produce toxins, called mycotoxins, that the mold uses to inhibit or prevent the growth of other organisms. Mycotoxins are found in both living and dead mold spores. Materials permeated with mold need to be removed, even after they are disinfected with cleaning solutions. Allergic and toxic effects can remain in dead spores. Exposure to mycotoxins may present a greater hazard than that of allergenic or irritative molds. Mycotoxins have been found in homes, agricultural settings, food, and office buildings.
DETECTION OF MOLD
How can I tell if I have mold in my house? If you can see mold, or if there is an earthy or musty odor, you can assume you have a mold problem. Allergic individuals may experience the symptoms listed above. Look for previous water damage. Visible mold growth is found underneath materials where water has damaged surfaces, or behind walls. Look for discoloration and leaching from plaster.
Should I test my home for mold? The California Department of Health Services does not recommend testing as the first step to determine if you have a mold problem. Reliable sampling for mold can be expensive, and requires equipment not available to the general public. Residents of individual private homes must pay a contractor to carry out such sampling, as it is not usually done by public health agencies. Mold cleanup is usually considered one of the housekeeping tasks of the private citizen, along with roof and plumbing repairs, sweeping and house cleaning.
Another problem is that there are few available standards for judging what is an acceptable quantity of mold. In all locations, there is some outdoor levels of molds. If sampling is carried out, an outdoor air sample needs to be taken at the same time as the sample indoors, to provide a baseline measurement. Since the susceptibility of individuals varies so greatly, sampling is at best a general guide.
The simplest approach is: if you can see or smell mold, you have a problem. Once you know the problem exists, follow the procedure given next.
Unless the source of moisture is removed and the contaminated area is cleaned and disinfected, mold growth is likely to reoccur.
GENERAL CLEAN-UP PROCEDURES
Identify and correct the moisture source
Clean, disinfect, and dry the moldy area
Bag and dispose any material that has moldy residues, such as rags, paper, leaves, or debris.
What can I save? What should I toss? Substances that are porous and can trap molds, such as paper, rags, wallboard, and rotten wood should be decontaminated and thrown out. Harder materials such as glass, plastic, or metal can be kept after they are cleaned and disinfected.
Ultimately, it is critical to remove the source of moisture first, before beginning remedial action, since mold growth will return shortly if an effected area becomes re-wetted.
Removal of Moldy Materials After fixing the moisture source and removing excess moisture, the cleanup can begin:
Wear gloves when handling moldy materials
Remove porous materials (examples: ceiling tiles, sheetrock, carpeting, wood products)
Carpeting can be a difficult problem -- drying does not remove the dead spores. If there is heavy mold, disposal of the carpet should be considered
Bag and discard the moldy substances
Allow the area to dry 2 or 3 days
If flooded, remove all sheetrock to at least 12 inches above the high water mark. Visually inspect the wall interior and remove any other intrusive molds. (This step may have to be carried out by a licensed contractor).
CAUTION: Spores are easily released when moldy material is dried out.
Soap Cleanup
Before disinfecting contaminated areas, clean the areas to remove as much of the mold (and food it is growing on) as possible.
Wear gloves when doing this cleanup
Use a non-ammonia soap or detergent, or a commercial cleaner, in hot water, and scrub the entire area affected by the mold
Use a stiff brush or cleaning pad on block walls or uneven surfaces
Rinse clean with water. A wet/dry vacuum is handy for this.
Disinfect Surfaces
Wear gloves when using disinfectants
After thorough cleaning and rinsing, disinfect the area with a solution of 10% household bleach (e.g., 1½ cup bleach per gallon of water). Using bleach straight from the bottle will not be more effective
Never mix bleach with Ammonia - the fumes are toxic
For spraying exterior large areas, a garden hose and nozzle can be used
When disinfecting a large structure, make sure the entire surface is wetted (floors, joists, and posts)
Avoid excessive amounts of runoff or standing bleach
Let disinfecting areas dry naturally overnight -- this extended time is important to kill all the mold.
CAUTION: Bleach fumes can irritate the eyes, nose, and throat, and damage clothing and shoes. Make sure the working area is ventilated well.
Can cleaning up mold be hazardous to my health? Yes. Exposure to mold can occur during the cleaning stage. Mold counts are typically 10 to 1000 times higher than background levels during the cleaning of mold damaged materials. Take steps to protect your health during cleanup:
When handling or cleaning moldy materials, consider using a mask or respirator to protect you from breathing airborne spores. Respirators can be purchased from hardware stores; select one for particle removal (sometimes referred to as a N95 or TC-21C particulate respirator). Respirators are not as effective removing bleach fumes, so minimize your exposure when using bleach or other disinfectants.
Wear protective clothing that is easily cleaned or discarded
Use rubber gloves
Try cleaning a small test patch of mold first. If you feel that this adversely affected your health, you should consider paying a licensed contractor or professional to carry out the work
Ask family members or bystanders to leave areas when being cleaned.
Work over short time spans and rest in a fresh air location.
Air your house out well during after the work
CAUTION: Never use a gasoline engine indoors (e.g. pressure washer, generator) -- you could expose yourself and your family to carbon monoxide.
Can Air Duct Systems become Contaminated with Mold? Yes. Air duct systems can become contaminated with mold. Duct systems can be constructed of bare sheet metal, sheet metal with an exterior fibrous glass insulation, sheet metal with an internal fibrous glass liner, or made entirely of fibrous glass. If your home's air duct system has had water damage, first identify the type of air duct construction that you have. Bare sheet metal systems, or sheet metal with exterior fibrous glass insulation, can be cleaned and disinfected.
If your system has sheet metal with an internal fibrous glass liner, or are made entirely of fibrous glass, the ductwork normally will need to be removed and discarded. Ductwork in difficult locations may have to be abandoned. If you have other questions, contact an air duct cleaning professional, or licensed contractor.
After I've cleaned everything as thoroughly as possible, can I still have mold odors? Yes. It is possible that odors may persist. Continue to dry out the area and search for any hidden areas of mold. If the area continues to smell musty, you may have to re-clean the area again (follow the cleaning steps given in this sheet). Continue to dry and ventilate the area. Don't replace flooring or begin rebuilding until the area has dried completely.
How can further damage to my home be prevented? Check regularly for the following:
moisture condensation on windows
cracking of plasterboard
drywall tape loosening
wood warping
musty odor
If you see any of the above, seek out and take steps to eliminate the source of water penetration, as quickly as possible.
Can Ozone air cleaners help remove indoor mold, or reduce odor or pollution levels? Some air cleaners are designed to produce ozone. Ozone is a strong oxidizing agent used as a disinfectant in water and sometimes to eliminate odors. However, ozone is a known lung irritant. Symptoms associated with exposure include cough, chest pain, and eye, nose, and throat irritation. Ozone generators have been shown to generate indoor levels above the safe limit. Furthermore, it has been demonstrated that ozone is not effective in controlling molds and fungi, even at high concentrations far above safe health levels. Also, ozone may damage materials in the home. For these reasons, the California Department of Health Services strongly recommends that you do not use an ozone air cleaner in any occupied residential space. Refer to the CDHS IAQ Info Sheet: Health Hazards of Ozone-generating Air Cleaning Devices (January 1998).
USEFUL PUBLICATIONS
Biological Pollutants in Your Home, 1990. Available from local ALA or U.S. EPA's IAQINFO. Concise booklet aimed at concerned or affected homeowner
Mold, Moisture & Indoor Air Quality: A Guide to Designers, Builders, and Building Owners, 1994. Available from Building Science Corp. (978) 589-5100 or info@buildingscience.com.
Moisture, Mold and Mildew in Building Air Quality (Appendix C), 1991. Available from U.S. EPA's IAQINFO. Illustrative and useful resource guide.
Repairing Your Flooded Home. Available from American Red Cross and FEMA offices. Excellent resource with details on technical & logistical issues.
Clean-up Procedures for Mold in Houses. Available from Canada Mortgage & Housing Corp. 800-668-2642. Effective, hands-on information for affected homeowner.
NIOSH Warns of Hazards of Flood Cleanup Work. National Institute of Occupational Safety and Health (NIOSH) Update. Aimed at flood emergency workers. 800-356-4674.
Factsheet on Stachybotrys atra (chartarum). CDHS Environmental Health Investigations Branch, April 1997. Summarizes information on S.A. and includes NYC recommendations for evaluating and remediating microbial contamination.
REFERRALS TO OCCUPATIONAL & ENVIRONMENTAL CLINICS
Association of Occupational & Environmental Clinics.
http://www.aoec.org/
American College of Occupational & Environmental Medicine. http://www.acoem.org.
FOR FURTHER HELP OR INFORMATION:
Contact your County or City Department of Health or Environmental Health
American Red Cross Disaster Response Tel: 213-739-5200 or call local chapter
U.S. EPA's IAQ Information Clearinghouse (IAQ INFO) Tel: 800-438-4318 or 202-484-1307 Phone assistance (9 am to 5 pm, EST) http://www.epa.gov/iaq/
CA Department of Health Services
Environmental Health Investigations Branch, 1515 Clay Street, 16th Fl., Oakland, CA 94612, 510-622-4500
Indoor Air Quality Section, 2151 Berkeley Way (EHLB), Berkeley, CA 94704, www.cal-iaq.org 510-540-2476
This INFO SHEET includes materials provided through the courtesy of the Minnesota Department of Health Indoor Air Program. It was produced in March 1998 by the CA DHS Indoor Air Quality Section
Last edited by Tiger Mountain Tile Inc; 11-28-2016 at 12:41 PM. Reason: update link
bbcamp is offline
Closed Thread
HTML code is On
Mold proedwards Cleaning, Restoration and Sealing 3 11-27-2011 04:30 PM
Mold Doone Cleaning, Restoration and Sealing 3 09-15-2007 09:16 AM
Mold ! Dimension tile Professionals' Hangout 30 04-24-2006 08:27 PM
Is this a mold? Steve in PA Professionals' Hangout 9 04-17-2005 09:52 AM
