Unread 09-09-2008, 10:45 AM   #1
T3
New master bath project
We're starting a new master bath. We're planning to go with a kerdi shower and ditra for the floor. I'll come back and fill in some project details but I'll start out with a dumb question:
Where can I quickly buy/order a Kerdi drain system? I'm in the Chicagoland area if that helps.
Thanks for your help!
Tom
Bitten by the bug.
T3 is offline   Reply With Quote
Unread 09-09-2008, 10:47 AM   #2
Mike2
Right here, Tom www.tile-experts.com .
Fast and friendly service. You'll also find a link to them in the TYW On-line store here.
Unread 09-09-2008, 11:11 AM   #3
T3
Thank you, Mike. I did give it a search effort which was apparently too feeble.
Tom
Bitten by the bug.
Unread 09-09-2008, 11:16 AM   #4
Dave Taylor
Dave Taylor's Avatar
Tom.....
When you get hold of Tile Experts..... say "Hi" to that other,
better lookin', smarter, richer Dave Taylor for me :----)
Dave T (DIY'er)
the net.
Unread 09-09-2008, 12:37 PM   #5
T3
Talking
Is that Dave Taylor also the owner of the sexy voice on the other side of the phone line when I called earlier?
I was about to place the drain order online with the expedited ship option when I decided to call, and ended up saving a few bucks when I was told the regular ground will get here in a coupla days anyway.
I'll have to go back for some Kerdi and Ditra after figuring out how much I need since it's no small change.
Tom
Bitten by the bug.
Unread 09-15-2008, 06:15 PM   #6
T3
Open bottom shower bench
I'd like to use a board (32"x11.25"x1.5") as a shower bench. It will be supported at the ends on 2x4 blocks and nailed at the back to a stud at 16".
Do you think that's enough support for it to be a tiled (stone) bench? Going by the deflection calculation alone it would seem so, but I want to check with you good folks.
Tom
Bitten by the bug.
Unread 09-15-2008, 07:12 PM   #7
Mike2
Tom, I'm afraid a 2x12 lying flat, supported at the ends of a 32" span will flex way to much for a tiled bench. The Deflecto tool measures deflection of sawn lumber fixed upright, not lying flat.
A better solution might be the Better Bench, the adjustable model seen here, if you have room for a 33.5" wide unit. http://www.innoviscorp.com/better-bench.php Properly installed it will support 400 lbs.
Unread 09-15-2008, 09:18 PM   #8
T3
In term of the Deflecto tool I was treating the 2x12 as the subfloor material and the blocks at the ends as the joists supporting it, but I guess that's not a correct way to treat it.
I totally did not think about the rectangular Better Bench but will look into it. I've seen a lot of the corner one in pictures but none of the rectangular that I can recall.
Thanks for the info, Mike!
Tom
Bitten by the bug.
Unread 09-15-2008, 09:21 PM   #9
Marge
Marge's Avatar
Tom, I noticed you admit to being "bitten by the bug". In most situations that is the first step in healing....around here, it is just an acknowledgment that you may be doomed.
Marge------
Unread 09-15-2008, 09:22 PM   #10
Mike2
Here's another picture of it in case you didn't see it on their website. http://www.innoviscorp.com/better-be...table_unit.php
Unread 09-15-2008, 09:24 PM   #11
Wow, Mikey, that's a picher of a two MIL bench there, eh?
Unread 09-15-2008, 09:30 PM   #12
Mike2
Yep. Rated for two MIL's plus their yippie runt dogs. Pretty cool, eh?
Unread 09-15-2008, 09:34 PM   #13
T3
Oh Marge, I am soo doomed in many ways. But at least here I have companies.
Good demonstration photos, Mike. Them be heavy duckies and vases.
Tom
Bitten by the bug.
Unread 09-15-2008, 09:38 PM   #14
T3
LOL! It didn't get the MIL reference at first until I looked at the Men in the love, I mean Left picture.
I am so doomed.
Edit: I blame CX for this! I honestly was thinking Mother-in-Law.
Tom
Bitten by the bug.
Unread 09-15-2008, 09:42 PM   #15
Marge
Marge's Avatar
As just recently evidenced.....I'd be a might concerned about that company......
Marge------
