Unread 08-05-2015, 10:43 PM   #16
cab
I'm using a trench drain so the height isn't an issue...sorry, I should have mentioned that...
I called Schluter and they have no problem with my plan.
The problem is the pebble tiles were cheap and the size difference between the pebbles is really large. Plus, I wasn't able to get the seams to disappear properly...my first time to lay these...
Anyway, appreciate the replies...
Chris
cab is offline   Reply With Quote
Unread 08-05-2015, 10:47 PM   #17
Tiger Mountain Tile Inc
Just FYI, the seams usually don't disappear. I typically pull about 50% of them off the sheets and hand install so that you can't see the seams.
If you have any extras you might try doing a mock up on a scrap piece of backerboard and grout them to see what it looks like. You might be surprised.
James Upton
Unread 08-06-2015, 04:57 PM   #18
916tile
TileCoach
916tile's Avatar
By trench drain do you mean a Kerdi-line drain? You don't want to integrate Kerdi with anything other than their drain products.
Isaac Ostrom
Northern California
www.youtube.com/916tile
916tile is offline   Reply With Quote
Unread 08-08-2015, 04:17 PM   #19
cab
Actually it's a trench drain called "whatadrain" with a bonded kerdi flange. Talked to many people who have used it and it came highly recommended. Check out the website of the same name.
http://www.whatadrain.com/
Chris
Unread 08-08-2015, 04:27 PM   #20
Chris, it'd be helpful if you add a link to the specific drain you're using so everyone would be on the same page when discussing it.
Need Suggestions Trey4U Tile Forum/Advice Board 5 05-27-2015 03:56 PM
Any suggestions.... Kilauea Professionals' Hangout 34 03-23-2009 09:30 PM
suggestions anyone!!!!!!! Spurs Tile Forum/Advice Board 12 09-05-2008 10:58 PM
I need some suggestions. Gary K Professionals' Hangout 23 05-08-2006 12:53 PM
Saw suggestions PaulWolpert Tile Forum/Advice Board 2 04-22-2004 10:49 AM
