Unread 09-25-2022, 10:06 AM   #1
8ballz73
framing opening for a 3x5 shower
Hello, been a while since being here. Going to be building a standard 3x5 walk in shower so I can purchase standard sliding glass door, does anybody know what dimensions the framing should be from stud to stud so the door s would fit? I came across the web that it should be 60 1/4 stud to stud but wanted to verify here. Thanks if anyone can help!
Abel
8ballz73 is offline   Reply With Quote
Unread 09-25-2022, 10:26 AM   #2
Welcome back, Abel.
Nobody's gonna be able to answer that until they know exactly how your shower is to be constructed, including the thickness of your chosen wallboard and the type and thickness of your tiles at a minimum.
And even at that, you'll still want to be sure there is at least a little adjustment available in the pre-made enclosure you select. I don't know that there is such a thing as a "standard sliding glass door," but you'll certainly want the exact dimensions of what you intend to use before you try to build a shower opening to fit.
A major consideration will be that the framing where the enclosure will fit be straight and absolutely plumb.
Unread 09-26-2022, 05:19 PM   #3
Yep, I'd buy the door first.
Unread 09-27-2022, 06:19 AM   #4
Abel, I've been doing a little shopping for sliding doors for my tub/shower. You'll see selections for a single sliding door with a fixed panel, and also for two sliding doors - AKA, bypass. The off-the-shelf units do have some adjustability, but it varies from manufacturer to manufacturer. Shop for the door and look at the specs and installation instructions.
As was mentioned be sure the left and right walls are plumb, and that the curb is level.
Unread 09-27-2022, 07:54 AM   #5
8ballz73
Yes your correct. After more research going with the sliding option since they allow room for modifications to the rails to fit the opening. Thanks
Abel
Best way to enlarge opening around shower faucet Sixto Tile Forum/Advice Board 15 08-12-2022 06:42 AM
Shower opening not plumb. Need Advice ryan29121 Tile Forum/Advice Board 5 05-04-2016 07:24 PM
Shower door opening JasonEldridge Tile Forum/Advice Board 2 07-02-2011 07:46 AM
Shower opening options MikeK Tile Forum/Advice Board 4 03-05-2006 12:17 AM
shower opening for curtain TileInEye Tile Forum/Advice Board 5 05-17-2003 01:33 PM
