Unread 09-13-2022, 11:41 PM   #1
Dr. Z
Dr. Z
Mix of tile and wood window trim
I’m building a shower where the tile on one of the walls reaches the side of an existing window.
Can’t move the window and I’m waffling on how to trim it out
Should I wrap the tile on the jamb and up to the window or stop the tile short (flush with the edge of the jamb) and add a wood trim?
I have a Schluter edge trim for the tile below and above the window.
I’m afraid that either way it’s going to look weird. What’s the “least weird” configuration?
Thx!
Dale
Dr. Z is offline   Reply With Quote
Unread 09-13-2022, 11:54 PM   #2
Welcome to the forum, Dale!
If you aren’t going to install a shower door, you could consider picture-framing the perimeter of the window with a chair-rail style tile (to mostly mimic traditional wood casing) and your choice of either tiling the jamb or using wood.
Unread 09-14-2022, 07:07 AM   #3
Are you continuing the tile along that wall over and under the window, Dale?
subway trim tile around window NowhereMan Tile Forum/Advice Board 20 01-15-2019 02:16 PM
Caulking tops of door trim and window trim? netrate Tile Forum/Advice Board 4 07-09-2016 01:22 PM
Tiling around window and door trim--raise the trim? bek Tile Forum/Advice Board 11 07-19-2008 02:37 PM
Need advise on tile trim window DumbCop Tile Forum/Advice Board 12 03-14-2005 09:47 PM
glass block window trim tile sang4201 Tile Forum/Advice Board 2 12-19-2003 02:50 PM
