Unread 07-13-2018, 05:19 PM   #1
Whose got a hack for making tiling easier...
On/off pedal switch for the tilesaw.
Back when I made this, all the commercially available pedal switches were too light duty for my 20 amp wetsaw. So I made this with a heavy duty switch from Granger, a 12 gauge cord, and a water resistant box.
Super useful gizmo when you are making intricate and delicate cuts and you want to stop the saw so that you can pull your "masterpiece" away from a still blade. I think we've all busted our fair share of tiles as we were pulling the tile away from the spinning blade and it grabs and breaks your tile.
Anyone else?
Unread 07-13-2018, 07:53 PM   #2
muskymike
muskymike's Avatar
You didn't have that when I did that job for you!
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 07-13-2018, 09:14 PM   #3
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
I salvage old tape measures and make lightweight, flexible, yard sticks out of them. I cut the tape at the 30ish inch mark and keep one at the saw and one with me on the floor/ wall. Use it to measure and don't need to worry about water rusting a $20 tape or thinset clogging one up.
I have old fatmax tapes where the spring gave out. But i did try it with a harbor freight tape that i got for free for spending a buck. One could, if they were shady at best, take said tape. Cut it at the 30 inch mark, keep the cut off part and exchange the housing for a new tape and repeat the cycle. But the hf tape quality isn't worth the effort.
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Unread 07-14-2018, 05:55 AM   #4
DownEastGC
Carpenter
DownEastGC's Avatar
You know... I was in the middle of tiling a shower the other day and was thinking about making a thread like this! :-D
Originally Posted by Shady At Best
"...shady at best"
I like the tape idea. I'm always so careful with my tapes when tiling so I don't get mud on/in them. It's annoying.
Ice Bucket for Epoxy Grout
I read that tip on here somewhere and it's amazing. I put the Laticrete Spectralock bucket inside another bucket of icewater. Definitely extends the working time of the grout.
This is a simple one but makes my life way eaiser. I take a small scrap piece of 3/4" plywood and use it as a "table" in the tub. Good for my laser. I put my mud buckets on so I'm not bending over 1000x. It's a more stable surface to stand on than trying to balance on the lip of the tub. Makes a nice seat. Easy to move (vs a step stool).
Chris
GC Specializing in Remo/Reno
DownEastGC is offline   Reply With Quote
Unread 07-14-2018, 09:32 AM   #5
smifwal
I use folding rules like my grandfather did. This one is a metric inside read. Imperial on the outside.
Unread 07-14-2018, 12:12 PM   #6
Simplyjames
Simplyjames's Avatar
Microfibers for grouting. Yes.
James
ACT certified installer #015
californiaflooringltd.com
Simplyjames is offline   Reply With Quote
Unread 07-14-2018, 12:37 PM   #7
Simplyjames
On a related note;
How does a guy avoid an electrified arm in this situation??
Add a ground to the tool somehow? This is starting to burn a bit.
James
Unread 07-14-2018, 12:56 PM   #8
smifwal
James
Something like this maybe?
https://www.amazon.com/26020008-6-Sh...52272940&psc=1
Unread 07-15-2018, 08:54 PM   #9
smifwal
I don't know if this is a hack bit I use these to clean buckets save on sponges. I cut them in half
Unread 07-15-2018, 08:55 PM   #10
Simplyjames
Originally Posted by smifwal View Post
Cool, I’m shopping this week.
Sent from my iPad using Tapatalk
James
Unread 07-15-2018, 09:26 PM   #11
Using a grinder that's meant to be dry in a wet situation like you're doing with the garden hose is prone to getting you shocked. If you add a GFCI, it'll keep you from getting shocked for more than a fraction of a second. But it'll shut your tool off in a fraction of a second.
... I use these to clean buckets save on sponges. I cut them in half
Yeah, those work good. Anybody use the drill attachment that sorta looks like a mixing paddle, but it has a drum instead with plastic-fingers to scrape/clean the inside of a bucket?
Unread 07-16-2018, 03:52 AM   #12
smifwal
I got one of them too. They can be messy, pretty sure that is why they are demonstrated in the middle of the yard. Not saying you can't use them in the house but it can get away from you. they work really well for that bucket you set aside and kind of forgot about. I don't use it much. I like to clean my buckets before each batch of mortar to get the pot life so the buckets don't get gnarly but the last bucket of the day. That thing makes short work of it with little effort. If you get one make sure you clean the inside of the "well" real good. It will fill up with thinset
Unread 07-16-2018, 01:50 PM   #13
Just In Tile LLC
Just In Tile LLC's Avatar
I've always used a gong brush for bucket cleaning.
Justin
Unread 07-16-2018, 05:03 PM   #14
K_Tile
Member of Million SF Club!!
James
Hold a wet sponge against the grinder blade while cutting.
Unread 07-17-2018, 10:24 AM   #15
I know a guy that use to set tile that never even bought a saw. He did the grinder/sponge thing, even on large jobs.
making and tiling a half column bender123 Tile Forum/Advice Board 9 06-10-2010 09:52 AM
Another Hack Job HS345 Professionals' Hangout 35 02-24-2009 10:26 PM
An easier way! mmoore Tile Forum/Advice Board 22 12-11-2008 09:07 AM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
