Unread 11-19-2012, 12:37 AM   #1
aaron0593
paper-faced glass mosaics
Hi
These glass mosaics i have, to do a kitchen backsplash, have paper on the face and very well stuck on.
What's the best way to get the paper off after thinset dries? Water is not going to work that great.
Aaron
aaron0593 is offline   Reply With Quote
Unread 11-19-2012, 07:24 AM   #2
Water should be all you need. If the thinset has cured, try adding some liquid dish soap to the water. Just a dab.
Got a pic of this paper faced tile? name of manufacturer?
Unread 11-19-2012, 06:06 PM   #3
MaskeoLad
Water and elbow grease are the only things I have ever used. They can be a bear sometimes, but one trick I have found is to wet the paper very thoroughly. Let the water sit for about 10 minutes and then come back and scrub with a sponge.
Hope it helps.
Matt
MaskeoLad is offline   Reply With Quote
Unread 11-19-2012, 06:21 PM   #4
reefone
tile setter
yes lots of water and a spray bottle. i spray the paper let it sit for a few then come back and scrub the water in with a wet sponge. let it sit for a few more then try peeling the paper. a lot of times the paper will tear and you will need to scrub the little bits off with a sponge. then some paper bits get caught in the grout lines and i take a vacuum to it and get it out that way.
Jerry
tile setter 12yrs exp.
Unread 11-19-2012, 10:12 PM   #5
aaron0593
thanks
I thought it was going to be a PITA. Thanks for the help.
Aaron
Unread 11-20-2012, 01:01 AM   #6
jerrymlr1
You could do a test with a small section of tile. I always remove the paper before the mortar sets. You can adjust any tiles that need it. Even the most difficult to remove paper can be removed to a point that you can adjust the tile. It's a little more delicate process. Just try to avoid drenching the open joints.
Jerry
Unread 11-20-2012, 06:59 AM   #7
Peerless Tile
Tile Contractor
I just had this thought and got curious.....Anyone ever try a little DIF (wallpaper remover) in the water of their spray bottle to soak the face paper?
SC Greg
Peerless Tile is offline   Reply With Quote
Unread 11-20-2012, 10:50 AM   #8
If you have it, use it. Plain old dishwashing liquid will do, though.
Unread 12-05-2012, 08:28 PM   #9
Crease
Crease's Avatar
I've never had to use anything but plain water. Some is stickier than others, but so long as you hold your mouth right it'll come off.
Crease is offline   Reply With Quote
Unread 12-05-2012, 09:09 PM   #10
Warmer water will be a little faster.
Sent from my new crappy phone
Unread 12-06-2012, 09:35 AM   #11
aaron0593
thanks
Thanks for the advice, there was no problem getting the paper off but many of the tiles were misaligned and had to be reset, and a fair amount of thinset had to be scraped away in the joints before grouting.
In my opinion, these particular glass tiles look terrible so i didnt take a picture. Clients seemed happy it was completed though.
Aaron
Unread 12-06-2012, 12:29 PM   #12
If thosetiles were made by "next to the sea" I'd be the first to agree they aren't the best finished looking glasstiles I have seen.
Paper faced glass tile. thuffner3 Professionals' Hangout 20 05-23-2009 09:44 PM
paper-faced glass tilejoe Professionals' Hangout 16 12-06-2008 10:33 PM
One-inch mosaic paper-faced tiles WoodyInMass Tile Forum/Advice Board 12 11-17-2008 05:42 PM
Removing Plastic from faced mounted mosaic glass tile oliverw Tile Forum/Advice Board 7 07-11-2006 01:56 PM
How to install paper faced tiles... Chuck_Newt Tile Forum/Advice Board 5 08-10-2005 05:43 AM
