Unread 03-06-2019, 12:02 PM   #1
Jonnyshark
Did I screw up? Kerdi help
To make it short. Can I use the unmodified thin set over quick set lite 45 and all purpose compound. I got ahead of myself.
Thanks for your help!
John
John
Jonnyshark is offline   Reply With Quote
Unread 03-06-2019, 12:12 PM   #2
Redlands Okie
https://www.schluter.com/schluter-us...et-mortar-type
I think so. Just be darn sure you dampen the sheetrock with a sponge or spray bottle or something similar before you apply the thin set. Do not get to far ahead of your self on the dampening part.
Robert
Unread 03-06-2019, 12:34 PM   #3
Lou_MA
I’d prime the joint compound first
https://www.schluter.com/schluter-us...ll-tape-joints
Lou
Unread 03-06-2019, 01:09 PM   #4
Jonnyshark
Do you recommend a particular latex primer? Kilz2 Latex for instance?
Thanks for the quick replies.
John
Unread 03-06-2019, 01:32 PM   #5
Lou_MA
Kilz2 latex would be sufficient
Lou
Unread 03-06-2019, 02:53 PM   #6
Redlands Okie
You can also put primer made for sheetrock and joints. Often listed as PVA .....
Lots cheaper than kilz and is actually made for it.
Box stores and professional paint stores will all carry something for the bare sheetrock or joints that usually is pretty economical.
https://www.lowes.com/pd/valspar-pro...yABEgJHj_D_BwE
Robert
Unread 03-06-2019, 09:15 PM   #7
Jonnyshark
I primed it today. Would it be ok to thin set membrane tomorrow?
John
Unread 03-07-2019, 10:27 PM   #8
Yes, as soon as the primer is dry
Unread 03-08-2019, 09:26 PM   #9
Redlands Okie
Depends on the primer you used. Look for the specs for it. Many are dry to the touch in perhaps a hour. But need to wait 3 or 4 hours perhaps to recoat. Longer to cure
Robert
Unread 03-17-2019, 11:44 AM   #10
Jonnyshark
Small gap between Kerdi wall and Tray
Is it OK or recommended to use thin set for the small gaps, 1/2 inch or less, between Kerdi covered sheet rock and Kerdi shower tray? Kerdi membrane has been installed from bottom to top.
Thank you!
John
Unread 03-17-2019, 11:49 AM   #11
Lazarus
Lazarus's Avatar
Thinset tends to shrink as it cures and 1/2" is a bit large to fill with it. You could mix up some brick morter (AKA "mason mix") and force it in...
Laz...
Unread 03-17-2019, 12:07 PM   #12
Depends. Specifically which mortar are you using, John?
Unread 03-17-2019, 12:09 PM   #13
Jonnyshark
Lowes Mapai uncoupling morter
John
Unread 03-17-2019, 02:02 PM   #14
Lou_MA
If Kerdi has already been installed top to bottom, the gap is behind the Kerdi??
Lou
Unread 03-17-2019, 02:43 PM   #15
Jonnyshark
The gap is between the sheet rock cover by kerdi membrane and the foam schluter shower pan. Due to the end of sheet rock slope.
John
Kerdi screw-up... modified thinset msavold Tile Forum/Advice Board 5 11-06-2010 07:30 AM
Kerdi Question (AKA how bad did I Screw up) mwpfop Tile Forum/Advice Board 91 01-01-2009 11:59 AM
Did I just screw up? Flexbond & kerdi agchoset Tile Forum/Advice Board 7 04-26-2007 09:39 PM
Screw Kerdi... BradH Tile Forum/Advice Board 39 11-28-2006 05:34 PM
Kerdi with Screw-on Grab Bar awmatt Tile Forum/Advice Board 3 08-09-2004 03:51 PM
