Unread 02-02-2009, 08:44 PM   #61
custombuilt
Tile and remodeling contractor
Jack... So the marble is removable to store the urns? interesting....
Jason W.
Superior Construction
Custom Interior and Exterior remodeling experts
Quincy, IL
custombuilt is offline   Reply With Quote
Unread 02-02-2009, 09:10 PM   #62
i just ordered a new camera phone, you guys just wait to see my mastic tiled tub surrounds and 20 sf bathroom 2x2 floors!
Unread 02-02-2009, 09:14 PM   #63
Kilauea
LT
Kilauea's Avatar
Here is some stuff in progress....nothin fancy,just spec homes/bread and butter.....
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 02-02-2009, 09:14 PM   #64
Hamilton
Bucket abuser
Hamilton's Avatar
Yes, the panels are all intentionally removable and intended to be replaced.
With each bracket, that adjusts vertically...they also adjust side to side.
Also there are spring loaded clips made of stainless that put a forward
pressure against the stone that allow us to adjust for plane and plumb.
On the under side of each bracket is a small L shape piece of metal the
stone rests on. We are using 1/16" horseshoe granite shims to keep the
joint consistent as we adjust the brackets. Its not thinset and mortar, but
any stone setter would understand and take to this within a short time. Today
was my first time working with this system and I actually got quite a few
pieces up. I'll try to get some better close ups of the brackets and framing
and report back either thurs. night or friday.
Jack Hamilton
Hamiltontileandstone.com
Temecula Tile and Natural stone contractor
Hamilton is offline   Reply With Quote
Unread 02-02-2009, 09:22 PM   #65
Hamilton
Bucket abuser
Hamilton's Avatar
I just thought of this, and I personally thought it was funny, but this system
we are using is like the TLS on steroids lol
Jack Hamilton
Unread 02-02-2009, 09:25 PM   #66
Rob Z
Guest
Posts: n/a
We have started a kitchen remodel which is pretty interesting. The wall seen in the first photo is the wall between the dining room and the kitchen. This wall carries the load of half of the roof of the second story, brought down through the attic above the kitchen, and down onto the steel I-beam in the basement below. The engineer gave us a spec for a flitch beam, which we have installed in the attic. This beam spans the opening between the kitchen and dining room and bears on two parallams at either end, which then transfer the load down to the I-beam where it is bearing over the block walls in the basement.
We built shoring walls (in the basement, one in the kitchen, one in the dining room and one in the attic) to hold up the roof while we got the flitch beam into place. We used come-a-longs and chain to lift it in place.
I'll have some more shots of this space soon. We have it insulated and closed in now, and we are getting ready to order the heating mat for the floor.
Unread 02-02-2009, 09:25 PM   #67
Hamilton
Bucket abuser
Hamilton's Avatar
L.T. Didn't mean to jump on top of you. I recognize your efforts and have
been there many times. Great pics bro! I gotta get some dinner and climb
in bed. Wish I could hang out later tonight.
Jack Hamilton
Unread 02-02-2009, 09:27 PM   #68
Kilauea
LT
Kilauea's Avatar
finishing mud and small kine profiling.....
Thats cool that you get to try something new,Jack,guarantee youre gonna ace it!Unfortanately for us this will be #15 spec home/same house/same layout/same tile/different location.Only difference is were polishing some more stuff just to break the monotany!!////My bad/I think I jumped over you..
*L.T.*
tandctile-dot-net
Unread 02-02-2009, 09:34 PM   #69
rob, in the second photo what is that 2x10 or 2x8 doing with the chain around it or laminated beam i cant tell what it is exactly??
Unread 02-02-2009, 09:40 PM   #70
kevjob
Licensed Remodeling GC
kevjob's Avatar
looks like the LVL flitch beam resting on 2x6 with chain for lifting into place?
kevin
Highlands Ranch CO, Bathroom Remodeling
kevjob is offline   Reply With Quote
Unread 02-02-2009, 09:43 PM   #71
Rob Z
Guest
Posts: n/a
Hi Rick,
Here is another photo. It is showing Eddy while he drills the holes for the carraige bolts that are going to assemble the flitch beam. There are two 1 3/4" X 9 /2" LVL's with a piece of 1/2" X 9" steel in between. I think the steel and the LVL's and the bolts all together probably weighed a bit over 400 pounds, maybe closer to 450.
Unread 02-02-2009, 09:45 PM   #72
Rob Z
Guest
Posts: n/a
Kevin called it!
Unread 02-02-2009, 10:17 PM   #73
duneslider
Utah Tile Contractor
A piece of steel in the middle! I have never seen that done before, sounds pretty cool.
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
duneslider is offline   Reply With Quote
Unread 02-02-2009, 10:17 PM   #74
madronatile
Tile Contractor -- Seattle, WA.
Hey LT-
In that last pic in #63 it looks like you're putting fat mud right on dimensional lumber-but in previous pics the curb is wrapped in paper and wire? Never seen it done like that, am I seeing things right?
figured it out on my own-its to screed off. i need to stop pouring curbs.
Matt
www.madronatile.com
madronatile is offline   Reply With Quote
Unread 02-02-2009, 10:21 PM   #75
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
Thats just to mud in the sides theres wire in the other pics.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
