Unread 01-18-2016, 10:19 PM   #1
Adamculp2
hydronic floor heat help
Need advice on hydronic floor heat. Doing a large two bathroom remodel and will be relocation the hot water heat into the floor. Existing subfloor to stay down and will not be removing the ceiling below. What are the best options to minimize floor assembly height? Would like to use schluter beckotec unless the is are better options with regards to floor hieght. And go. Thanks for the help.
Adam
Adamculp2 is offline   Reply With Quote
Unread 01-18-2016, 10:40 PM   #2
Other methods that I'm aware of would require a thicker mudbed than Beckotec unless you wish to change to electric.
Unread 01-26-2016, 05:14 PM   #3
Adamculp2
Hot water floor heat alternatives
Need advice on hydronic floor heat. Doing a large two bathroom remodel and will be relocation the hot water heat into the floor. Existing sub-floor to stay down and will not be removing the ceiling below. What are the best options to minimize floor assembly height? Would like to use schluter beckotec unless the is are better options with regards to floor height. And go. Thanks for the help.
____________
Adam
Unread 01-26-2016, 05:51 PM   #4
Welcome, Adam.
I've combined your new thread with your previous thread on the same project. Please keep all your project questions here.
I know of no way to install your hydronics on top of a wood framed floor with any less gain in height than using Bekotec.
You've evaluated your floor structure to see if you're qualified for a ceramic tile installation without any structural improvement?
Unread 01-27-2016, 06:12 AM   #5
tilemanct
Tile & Stone
Make sure you talk with a heating pro. You cant take regular hot water baseboard and convert it to radiant in floor heat without manifolds, controls and zoning. The design temp of a hot water baseboard is way too high for radiant. Could be costly. Bekotec is 1 1/2" in thickness just for the panels.
It might be cheaper to do electric radiant in those areas.
CTEF Certified Installer
Unread 01-27-2016, 09:56 PM   #6
PetrH
I'd say your best bet is to rip out the subfloor and install pex runs in the joist spaces below. Plywood is cheap compared to all the other stuff. Normally that's stapled in from below, but I'm sure you can figure out a way that will not involve having a flooring screw go through the lines.
Petr
Unread 01-28-2016, 12:07 AM   #7
T_Hulse
Tile Contractor
T_Hulse's Avatar
Hi Adam, with Bekotec, your minimum thickness with a 3/8" tile will be around 2 3/8" finished total.
Using TCNA method RH123, with self leveling underlayment, you can cut that down to about 1 11/16". (both methods would be above your highest point on the floor)
Tom Hulse
Visit my web site here
Unread 02-01-2016, 07:28 PM   #8
Adamculp2
Thanks for all the help. I will look at the self leveling method and taking up the sub-floor. I am working with a heating contractor as well. This room will have a new zone installed from the manifold. There is no additional structural improvements need for the addition.
Adam
Gypcrete over hydronic heat JR Tile Forum/Advice Board 8 12-04-2010 08:14 AM
float over hydronic heat pooky Professionals' Hangout 7 03-27-2009 01:57 PM
Hydronic heat over basement slab InOver Tile Forum/Advice Board 5 05-22-2008 06:56 PM
does felt smell under hydronic radiant heat floor? jane voichick Tile Forum/Advice Board 3 08-07-2006 06:10 PM
hydronic heat John Farnan Tile Forum/Advice Board 2 11-01-2005 06:18 PM
