Old 04-15-2019, 09:27 AM   #1
duxsi
Replacement for Aqua Mix Renue
Good morning all.
I have some etching on my honed travertine kitchen floors.
Can you please recommend a product / process that will get some of the dullness out of the stone as well as provide a slight shine.
A few older posts recommended Aqua Mix Renue (which has been discontinued).
I have attached pictures.
Thank you in advance.
duxsi is offline   Reply With Quote
Old 04-15-2019, 11:47 AM   #2
claycarson
Commercial Cleaning and Maintenance
It's hard to think of a product that will do what you're looking for.
We do it for a living and it can't usually be reduced to 'wipe this liquid on and it will work'.
Etch removers are often slightly acidic like polishing powders, so they can 'dig in' a bit. But that means they can dull the surface if applied too heavily, re-creating the original problem.
Sent from my SM-G920T using Tapatalk
Clay
www.tileboston.com
claycarson is offline   Reply With Quote
Old 04-15-2019, 02:22 PM   #3
duxsi
Thank for the reply.
There is no sheen on the floors as of today and I expect their to be some dulling during the cleaning process.
I anticipate that they will need polishing at some point in the near future.
The only immediate issue is that the etching makes them look soiled.
Old 04-15-2019, 06:26 PM   #4
If you were to use a topical film finish, I think you’d be forever fighting to apply the stuff to just the dull areas. And if you applied it to the entire floor, it’s such a high-maintenance finish that you’d be unhappy with it. Then unhappy having to strip it.
I’m with Clay that polishing to bring back a microscopically smooth surface is what you want. You may want to consider honing the floor to a duller overall sheen in an effort to keep your floors looking good without the higher maintenance of a higher sheen. As an added bonus, it would save some money over the higher sheen polishing.
Help an awesome summer camp finish their cabin after 10 years in the making. They are only $75,000 away.
Old 04-15-2019, 07:10 PM   #5
duxsi
Thanks to you both of you for the advice.
Polishing will be the way to go.
Dux
aqua mix mix up handifoot Cleaning, Restoration and Sealing 4 06-14-2010 12:27 PM
Aqua mix Tim T Tile Forum/Advice Board 1 03-24-2007 09:13 PM
Aqua Dec Gattas Tile Forum/Advice Board 0 06-18-2006 03:12 AM
Aqua mix 15 keastman Cleaning, Restoration and Sealing 3 01-23-2006 06:29 PM
Aqua Mix??? miss piggy Tile Forum/Advice Board 1 05-05-2004 02:28 PM
