Unread 02-22-2016, 04:22 PM   #1
devin98
curbless shower questions
Hey Everyone,
Long time reader first time poster have a quick question.
We are attempting to build a 4' x 6' curbless shower into a bathroom remodel, we do not have the luxury of reframing the floorjoists sadly so unable to create a larger floor joist drop that would normally be used for curbless.
The floor joists are 2x8's and span around 15', we will be building up the bathroom tile floor with scratch coat, heated floor wiring, another scratch over that, thinset and tile I would expect it to be almost 1 inch after all said and done.
Can anyone recommend a good way to complete a slope to a linear drain along the back wall without cutting floor joists?
-Devin
Devin
devin98 is offline   Reply With Quote
Unread 02-22-2016, 05:39 PM   #2
koihito
A person, like you.
koihito's Avatar
Are you sure about the 2x8 and 15' span? That would make for a VERY bouncy floor wholly inadequate for tile.
As for the curbless shower without cutting joists, I would be looking at either Finpan's Clearpath Shower kit or Wedi.
Nate
www.mikoskiconstruction.com
Unread 02-22-2016, 05:47 PM   #3
I agree with Nate. Double check that joist span. At best, it should be no more than 10-11 feet.
Your linear drain placement is going to be dependent on the joist direction and dimensions of the shower. I would look at the two that Nate mentioned, and contact their customer support directly with your plan.
If the shower is 6' from front to back, I don't know how you'll get your required minimum 1/4" per foot slope without having a bump at the opening, or building up the floor in the rest of the room. A centered linear drain might be more feasible.
Unread 02-22-2016, 06:01 PM   #4
reefone
tile setter
id like to know what this scratch coat you are talking about is?
Jerry
tile setter 12yrs exp.
Installing a curbless shower over TGI questions mane3215 Tile Forum/Advice Board 19 10-19-2013 04:31 PM
Curbless shower questions bpittman13 Tile Forum/Advice Board 22 04-12-2013 12:23 PM
Curbless Shower Questions.. Oebur Tile Forum/Advice Board 9 04-06-2012 10:49 PM
Questions about doing a curbless shower Jay_bee Tile Forum/Advice Board 4 01-14-2012 10:17 AM
Handicap curbless shower questions slayer73 Tile Forum/Advice Board 7 09-12-2007 08:52 AM
