Welcome, unccivil. Please put a first name in a permanent signature line for us to use.
Sounds like you could add deeper sisters on only one side and save a good bit of work and some dinero.
But now that the subflooring will be removed, you might reconsider your mid-span bracing. Far more bang for the buck there if you can get the old joists to flatten out.
Originally Posted by unccivil
add support columns (if needed) for the outer and center beams to handle the added joist weight (200lbs or so to each 8' beam span)
Can't comment on that at all without more information.
Has anyone ever done this or seen it done?
Seen what? Sistering joists? If you'll look about the site just a tiny bit you'll see that we recommend it several times a day, on average. Very common way to bring insufficient joist structures up to par.
