Unread 11-10-2019, 09:46 PM   #1
ItchyVols
Bradley’s fireplace surround
After having good success tiling my bathroom I’ve decided to tackle another project for which I am under qualified. The previous tile was laid such that it was higher than the level of the surrounding hardwood. I would like to ensure that the tile I lay is flush with the hardwood
The vertical tiles of the surround were laid on top of the original tiles that were set there which was laid on top of about an inch thick mud bed which was on top of brick. So there is a hefty chunk I have to build back out to have a proper substrate on which to lay my tile.
What I need to figure out now is how to level out the floor substrate once I have demo’d down far enough - slc, cbu, or just mud? And also how to build out the vertical aspect to be plum or just shy of the trim that is there - cbu or mud?
Bradley
ItchyVols is offline   Reply With Quote
Unread 11-10-2019, 10:00 PM   #2
I'd use mud for both areas. Wall mud on the face and deck mud for the hearth. For the face, I usually set 1x4 boards around the inside of the firebox and use them as screeds. Cut the side boards to fit tight enough to hold the top board in place.
Bradley’s master bath ItchyVols Tile Forum/Advice Board 20 10-22-2019 09:54 AM
fireplace surround diy noob Tile Forum/Advice Board 1 11-28-2012 10:54 PM
fireplace surround CAKMOM2 Tile Forum/Advice Board 5 09-02-2010 01:19 PM
fireplace surround red3 Tile Forum/Advice Board 0 07-17-2009 02:05 AM
Fireplace surround help Deadpool9 Tile Forum/Advice Board 5 12-06-2008 07:54 AM
