Unread 10-17-2012, 01:39 PM   #1
Ed Williams
More discoloration of carrara marble in shower
I am having the same problem except with a linear drain.
We have the small marble tiles on the floor like you do.
Did you get your problem resolved ?
Can't believe I put some much into this bathroom and have not been able to use it.
Edward
Ed Williams is offline   Reply With Quote
Unread 10-19-2012, 09:05 AM   #2
Tiger Mountain Tile Inc
Ed, can you tell us a little bit more about your shower?
What kind of linear drain did you use? Do you know if you have a liner in your shower or is it a Schluter type linear drain?
Photos are very helpful also.
James Upton
Why you should NOT buy a newly remodeled home ~DIYTileGuy
Unread 10-19-2012, 09:21 AM   #3
Welcome, Edward. Should we call you Edward or Ed?
I separated your post from that other fella's thread so your particular problem can be dealt with without confusion with his problem's differences.
As you can see from the first response, we'll need a good bit more information to assess your situation.
carrara marble darkens in shower wall kel2sean Tile Forum/Advice Board 3 08-29-2012 05:00 PM
discoloration of carrara marble in shower Stockholmco Tile Forum/Advice Board 14 08-04-2012 08:10 AM
carrara marble shower Lou_MA Tile Forum/Advice Board 4 03-28-2012 08:09 PM
Advice for installing carrara marble slabs in shower Dolcevita Tile Forum/Advice Board 3 12-18-2008 12:42 PM
Carrara marble geetpicker Professionals' Hangout 4 06-30-2006 03:07 PM
